Results 1 to 12 of 12
Thread: Newbie...Pump/filter maintenance and monitoring
    May 2015
    TN
    312
    I have a 20-24k (not exactly sure yet) pool, vinyl, 18x36 that we adopted when we bought our house... It has a Hayward filter, and I am not really sure of the pump brand. I also have a booster pump for my Polaris 280. I will attach pics. The actual pool pump was replaced in late Summer of 13. Sand was changed 3 years ago.20150515_082613_resized_1.jpg
    My questions:
    1:What things do i need to perform maint. on?
    2: I do know to backwash. However, I don't know how many times in a period of time. I have heard so many different things.
    3: O-rings... Which ones can I check and change and how often do I lube them?
    4: What else am I missing?
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Newbie...Pump/filter maintenance and monitoring
    Welcome to TFP!
    Do you have a test kit from the Test Kit Comparison?
    Here are some intro Pool School articles
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
    Backwash your filter when the pressure rises 20-25% above the clean pressure.
    Here is everything you ever wanted know about a sand filter,
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just to add one thing on the topic of sand filters, sand almost never needs to be changed, it should last the life of the filter / pool
    May 2015
    TN
    312
    Yes, I have a Taylor k2006 kit. Switching to methods taught here. Have been getting cya level down from well over 100. My pump doesn't have a pressure gauge. Hmmmmm
    DFW, TX
    24,502
    Pressure gauge on the filter, not the pump.
    May 2015
    TN
    312
    Don't have one there either
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You should have a socket for one, 1/4 inch NPT fitting, probably with a plug in near the top of the filter.
    May 2015
    TN
    312
    Quote Originally Posted by Isaac-1 View Post
    Yep! Found it. Do I just unscrew that and screw pressure gauge in? Surely it isn't that easy!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Almost that easy you will need to wrap the threads with teflon tape or use pipe dope to keep it from leaking.
    May 2015
    TN
    312
    Got ya! Will the pump need to be turned off?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It will be less interesting with it turned off, you will be less wet afterward also.
    May 2015
    TN
    312
    You just took all the fun out of it!!!
