Thread: Pool steps heaving
    Apr 2012
    Richmond Hill, ON, Canada
    10
    Unhappy Pool steps heaving
    Hi, I posted here a couple of years ago about my inground pool steps heaving. Since then, I have had:
    - the cracked concrete deck replaced and the cracks in the original steps repaired (2011),
    - the new deck removed and the steps completely replaced after they cracked again, along with a new liner and another new deck (2012),
    - the new steps repaired after they cracked again above the water line (2014)
    Now they're worse than ever . They have heaved out of the concrete and cracked in two places. In doing so, they have pushed the whole slab up, resulting in multiple cracks in the patio (the concrete deck was extended into a patio). The coping has separated from the concrete all along the right hand side of the pool.
    I am at my wit's end.
    I am thinking at this stage that I only have a few options:
    - have all the concrete removed, the step replaced again and interlock laid where the concrete was. Not sure if this will help with the step heaving, though. Maybe I need what they call a "French well" or sump pump?
    - install drop-in steps or the kind of in-pool steps that are covered by the liner (I'll probably need to replace the three-year-old liner anyway because of all the other issues). This would require the pool company to put a new section of wall in; with this option, maybe I could just have some of the concrete removed to get the steps out and replace it with the same material. I will probably need to see if they can cut a six-inch band around the perimeter of the pool to allow for the coping to be replaced and have the gap filled with a contrasting band of concrete
    - fill the whole darn thing in and lay grass
    I am in the Toronto (Canada) area, so we get some pretty severe winters. I have lots of friends and neighbours who have pools, though, and none of them have had the kind of issues I've had.
    Any advice, similar experiences or cost estimates would be appreciated.
    Thanks in advance.
    Re: Pool steps heaving
    tough road for you to date.
    would you have any pics to post? that may help others to visualize your pool and issue.
    best of luck.
    Apr 2012
    10
    Quote Originally Posted by Lordcore View Post
    best of luck.
    Hope this works. Here is a picture of one of the cracks as it appeared in the spring of 2013. On the advice of a pool guy, we decided to leave it and see how it fared through the winter of 2013-14. We had a mild winter and it didn't get any worse, so we had a guy fill it with resin last year. I haven't been able to take a picture of it yet this year because we haven't shocked the pool or taken the cover fully off, but that crack has opened up again, the step is a couple of inches forward at the top from where it should be (out of the concrete) and it now also has a large crack at the bottom on that side, well below the water line.
    Oops, that top photo is upside down but I don't know how to flip it. Please just try to imagine it the other way around!
    Apr 2012
    10
    Any observations that anyone wants to offer now that I have posted photos? Please?
