Thread: Alternative Pool Construciton Methods
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am starting this thread to ask what types of alternative in ground pool construction are you aware of that is currently being utilized in the industry outside of the common gunite, shotcrete, vinyl liner, pre-cast fiberglass pools, or buried above ground pools? In the past we have seen everything from repurposed steel landing craft to hybrid concrete pools with fiberglass walls used in swimming pool construction.
    So what else is out there, and what are your thoughts on it as a viable alternative to conventional in ground pools?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Alternative Pool Construciton Methods
    Interesting you should ask this because I'm starting the long term planning of what I think will be an alternative pool. We have just purchased a house in the mountains that will become our retirement house in the next couple of years. The house is built on top of a hill with the main yard approximately 15 feet below. I'm thinking something like a concrete block wall with a vinyl liner inside. Gotta start doing some research.
    Support the site
    4knights's Avatar
    NE Kansas
    419
    Saw a pool that was cut out of limestone or granite - (like a quarry) on TV- dream home type show. It cost a fortune but was incredible! Heated, Lights, a waterfall, sloped access, about 30ft deep on deep end.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Aug 2014
    Shallotte, NC
    693
    My pool started out life (we believe Buster Crabbe Pools may be the manufacturer) as a concrete base and wood walls with liner..... Apparently, in Europe, a version of this is still accomplished: here.
