Results 1 to 12 of 12
Thread: Is there any way to add a pressure gauge to a stock Intex 1500gph pump/filter?
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Is there any way to add a pressure gauge to a stock Intex 1500gph pump/filter?
    I don't believe so. Only sand and DE filters can have gauges. I love my sand filter. Have you considered getting a sand filter?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Pooler, GA
    311
    I have, eventually. I am about tapped out with additional costs right now. Probably in a few months.
    TF-100
    Helpful Links
    Jul 2014
    Oakbank, Canada
    389
    If the pump never came with it, why do you need it now?
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There are always ways, but I have to ask if it is worth it since those pumps can't develop much pressure
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    Just buy a 1/8" npt Guage and drill tap with some pipe dope. If there's not enough meat where you can put it, just drill a hole and thread a nut on the back side with a piece of rubber creating like a gasket.
    10k gallon 22' AG Vinyl, 2k got Cartridge Filter, Fresh water, BBB Method baby!
    Jul 2014
    Oakbank, Canada
    389
    Quote Originally Posted by Isaac-1 View Post
    Exactly, so why bother to install one now?
    May 2015
    Pooler, GA
    311
    I had just read that a gauge is the best indicator to show when it is time to clean your cartridge.
    I'm new to all this, so I'm just hanging on to advice I read in multiple places that seems to pass the common sense test.
    TF-100
    Helpful Links
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    To be honest, the most practical way of gauging when to clean is to monitor the output force of the water coming out compared to the force when it's clean.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Agreed.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I agree with FUBAR and Pool DV. I ignore my guage most the time. I just check the water flow coming from my return. If it slows, I backwash. In your case if it slows, change your filter.
    Lisa
    Jul 2014
    Oakbank, Canada
    389
    Yeah, just put your hand in front of the output and before cleaning and than again after. You will see the difference and relate to that later.
