Results 1 to 12 of 12
Thread: First Time Pool Owner and Results of Test Scary...WHAT DO WE DO?
    May 2015
    Hudson
    16
    To all that can help shed some light on my pool that came with our new house near Boston (place given incase weather matters).
    We have never had a pool but the pool is an above ground pool that is 4' by 18-20' circle.
    We have only run the filter without shocking or adding any chemicals since we took the cover off and filled it to the remaining fullness.
    What we find scary is the results but are unsure what to do, and have tested twice (once by my wife and once by me from different locations around the pool) roughly resulting what I feel as the same.
    Here they are:
    Pool testing with Taylor K-2006
    PH: 7.0
    11 drops to get to 7.5 PH
    Total alkalinity
    10 drops equals 100ppm as calcium carbonate
    Calcium hardness
    50ppm calcium carbonate
    Cyanuric Acid
    Too low to read just where the black line is
    15ppm free chlorine
    .4ppm combined chlorine
    Test 2:
    PH 7, 10 drops of r-006 to get to 7.5
    Total alkalinity
    9 drops equals 90ppm calcium carbonate
    Calcium hardness
    40ppm
    Cyanuric acid
    Just below black mark way below last number
    Chlorine:
    Free chlorine is present
    13.8ppm
    Combined chlorine is present
    .6 ppm
    Question being is how should we proceed, any insight would be splendid...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: First Time Pool Owner and Results of Test Scary...WHAT DO WE DO?
    Welcome
    Well... the pH test is somewhat unreliable with FC above 10. But if it's reading right, you're a bit low. That's pretty easy to fix. The CYA is low, that's also easy to fix. The FC is a bit high for everyday, but if you're green or cloudy, you're only a tad high. It'll go down with sunlight quick enough. What does the water look like?
    Before you can fix anything, you need to figure out the pool's volume, which means you need to be more accurate about the diameter. Also stick a tape in and see how deep the water is, not the sidewall.
    Knowing the dimensions, we can get a close approximation of the volume and let poolmath crunch the numbers and calculate the doses you need you fix things.
    So... measure the pool and report back and tell us what the water looks like as well.
    As an aside, you can use 10 ml of water when doing the FC-CC tests. Each drop counts as .5, which is high enough resolution for us. Also, you only need enough powder so that you have a few crystals undissolved before you start. Taylor encourages you to use a whole bunch.... the same way the coffee sellers recommend you use their product!
    May 2015
    TN
    312
    Richard, they said their cya was way below the numbers... I'm confused. Doesn't that mean it is high?
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by lindz18 View Post
    Good catch! We'll need some clarification on that!
    May 2015
    Hudson
    16
    If I were to guess 150-200 since there are no numbers below the 100 mark (meaning there is very little liquid in the small container). Does this mean we need to drain the entire pool or are there alternative solutions or another test we should run before considering this?
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I'm important to have a good understanding of the CYA number. Is it really low (like 10), or really high, like 100+? It's not clear from what you say.
    This is important to know, because IF your CYA is really high, the advice here will be to lower your CYA through draining and replacing water...if you need to do that, it's best to do that first. CYA can get super high if the previous owner used chlorine pucks.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    May 2015
    Hudson
    16
    The CYA is definitely way over 100 because there is very little water while doing that test. They only list the numbers from 30 being near the top of the tube to 100 being about halfway down and we only have maybe 1/8th of it full.
    Is there something else we should try before draining? Like do the 10ml test for a third test just to confirm or buy another testing kit?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Figmentor View Post
    You could try the dilution test to get a ballpark idea just how high the CYA really is, so you can guesstimate how much water you'll need to drain. Post 8, Step 9
    If the pool is vinyl lined, you have to leave a foot or so in it so the liner doesn't shift por wrinkle.
    May 2015
    TN
    312
    I feel your pain on the cya!!! Just completed three drains and refills over a period of three days. My cya was showing just below 100 on the diluted test AFTER a large refill.
    Just below meaning in physical location in the vial... CYA was higher than 100.
    May 2015
    Hudson
    16
    So we drained the whole pool, and refilled...After running a brand new cartridge for 36+ hours straight here are the test results:
    Test 1 all new water 5/27
    Chlorine:
    10ml sample
    -After adding R-0870 sample turned ever so slight pink
    -2 drops of r-0871 to turn clear
    - .5*2 drops is 1ppm free chlorine
    - after adding 5 drops of r-0003 almost not present pink
    - 1 drop of r-0871 x .5 = .5ppm combined chlorine
    PH test:
    7.75
    Acid demand test took 1 drop to bring to 7.4
    Total Alkalinity:
    -took 8 Drops of r-0009 to turn red
    -8 drops x 10 = 80ppm total alkalinity as calcium carbonate
    Calcium Hardness:
    -after adding 5 drops sample turned pink
    -after adding 4 drops sample turned blue
    -4 drops x 10 = 40ppm calcium hardness as calcium carbonate
    Cyanuric Acid:
    40ish held over iPhone light
    42" deep
    15' diameter
    4.6k gallons of water
    So where to start? What to adjust first?
    I used the pool calculator but seems as you adjust one test the others will change. So is there a first then test for the other again?
    Best,
    ~Allen
    Hudson, MA
    May 2015
    Hudson
    16
    Also I attached but haven't used a Hayward CL200 Automatic Pool Chemical Feeder. What setting do I set that to after adding the pucks?
    The CYA test is best done in sunlight, with your back to the sun. So the test vial will get lots of bright, but indirect light.
    If your CYA really is 40, you don't want to use your Hayward CL200, because the pucks will continually add more CYA, and you'll be back where you started. Best to use liquid chlorine (aka "bleach").
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
