Thread: First Time Pool Owner and Results of Test Scary...WHAT DO WE DO?
    May 2015
    Hudson
    16
    To all that can help shed some light on my pool that came with our new house near Boston (place given incase weather matters).
    We have never had a pool but the pool is an above ground pool that is 4' by 18-20' circle.
    We have only run the filter without shocking or adding any chemicals since we took the cover off and filled it to the remaining fullness.
    What we find scary is the results but are unsure what to do, and have tested twice (once by my wife and once by me from different locations around the pool) roughly resulting what I feel as the same.
    Here they are:
    Pool testing with Taylor K-2006
    PH: 7.0
    11 drops to get to 7.5 PH
    Total alkalinity
    10 drops equals 100ppm as calcium carbonate
    Calcium hardness
    50ppm calcium carbonate
    Cyanuric Acid
    Too low to read just where the black line is
    15ppm free chlorine
    .4ppm combined chlorine
    Test 2:
    PH 7, 10 drops of r-006 to get to 7.5
    Total alkalinity
    9 drops equals 90ppm calcium carbonate
    Calcium hardness
    40ppm
    Cyanuric acid
    Just below black mark way below last number
    Chlorine:
    Free chlorine is present
    13.8ppm
    Combined chlorine is present
    .6 ppm
    Question being is how should we proceed, any insight would be splendid...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: First Time Pool Owner and Results of Test Scary...WHAT DO WE DO?
    Welcome to TFP!
    Here are some intro Pool School articles
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool and how to add them.
    Use PoolMath to figure out how much to add.
    38,251
    You FC is way high for how low your CYA level is.
    But, the most pressing is the pH being too low. Raise that up into the 7s with borax, no need for 7.5, just get it over 7.2 so you can read it.
    The high CC is also concerning.
    I would get the CYA up to around 30ppm ... then continue the ShockLevelAndMAINTAIN Process until you pass the 3 criteria to stop.
    BTW, use a 10ml water sample for the FAS-DPD test or you are going to run out of reagent very quickly. In fact, you should just order some refills now ... for both the FAS-DPD and the CYA test.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
