Thread: Setting Up 20 Ft 52 In Vinyl Pool
    Setting up a 20 Ft 52 In vinyl pool with a 120 volt sand pump that comes with pool. What do I need to put in the water starting off. Shock? Bleach? Stabilizer? The pool is in full sun all day.
    20 ft 56in
    Easy Setup Pool Owner
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Setting Up 20 Ft 52 In Vinyl Pool
    Welcome to TFP!
    First question I have is, do you have one of the Recommended Test Kits? Without a good test kit and the willingness to trust your own test results, we cannot give accurate advice on how much of what chemical to add.
    Generally speaking, you want to make sure your pH is between 7.2 and 7.8. After that, you want to add chlorine and CYA to the water. But again, without test results, we cannot say how much of what to add.
    BTW, are you in New Haven, CT or New Haven, KY? When most people see "New Haven", they will likely think of the city in CT. I would add the state to your location to clarify. Our advice often depends on the climate in your specific location.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    You know you'll need bleach. And you know you'll need stabilizer because tap water has none. Beyond that, nobody knows without test results. Test strips don't cut it, nor do pool store results. Even if the store was right (less than 10%, I'd guess) they'll still sell you stuff you don't need, or stuff you do need at 4X what it costs at the grocery store. Order a test kit. Best investment you'll ever make for the pool. http://tftestkits.net/TF-100-Test-Kit-p4.html
    Almost forgot.... Welcome
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    Get the TF100 kit, it'll last you at least 2 seasons. Research the BBB method. You'll be golden.
    10k gallon 22' AG Vinyl, 2k got Cartridge Filter, Fresh water, BBB Method baby!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
