Thread: pump starting to whine
    Apr 2015
    France
    1
    Hi, we have an outdoor spa, water quality is good, but pump has just started to whine, not high pitch, just a low whine, we have checked the pump and no air escaped as we loosened the joints, turned it all back on and it was slightly more noisy, had to have a new pump 2 years ago after a burnout from air in the system, keep water levels high ever since, but have noticed on most of the pipes there is an oblong box which looks like it has a small plunger attached and held in place by a short removable stop, we haven't touched these, unable to send phot as it is the middle of the night here and haven't been able to sleep worrying about the spa
    Outdoor spa brought in france under the name Phybris spa model Zonza, has 41 jets, holds 900 ltrs, or 200 uk gallons,came with instruction book in English with the name of make Spaking USA
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: pump starting to whine
    I do not have an answer to help you, but wanted to say Welcome to TFP! Someone here will probably have some ideas.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Usually whining from a pump is a motor bearing failing. If caught in time, they can be replaced. No idea what the plunger things are you mention without a picture.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
