Results 1 to 7 of 7
Thread: Frustrated Newbie
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Frustrated Newbie
    New to Pool ownership here, and already frustrated. We bought this house recently, and have a 20x40 inground saltwater pool. The problem is we cannot get it to clear up.This might not be the right forum, sorry.
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Frustrated Newbie
    Welcome to TFP!
    This forum works for now. We need more details. A full set of water tests would be great, is it cloudy, clear, green, a swamp - what are we dealing with?
    Do you have a test kit or have you been using the pool store testing?
    You say in ground, but plaster/finite or vinyl lined?
    WHat have you added so far to fix it?
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP! Tim post will get you started.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Welcome!
    Don't worry about posting in the wrong forum. A moderator can move it easily enough.
    If you're serious about taking control of the pool....
    Step one: invest in a proper test kit and some salt test strips. Best buy is the TF100. You probably won;t be able to find the other recommended kit, the K-2006 in stock anywhere, and the K-2005 isn't the same, no matter what the pool store clerk tells you.
    Step two: do some reading here. Start with the ABCs and Recommended Chemicals and How to Use Poolmath and Water Balance for SWG.
    Step three: run the tests when your kit arrives and we will guide you the rest of the way. We know where you want to be, we just need to know where you are, which is what the test results tell us.
    And please don't get impatient and start buying everything the pool store pushes at you. Just grit your teeth and wait it out and you could very easily have the pool tamed in a couple weeks and never have cloudy or green water again. Many of us have gone years without algae.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What Richard said
    FUBAR's Avatar
    May 2013
    Charleston, WV
    61
    Hang in there and heed these people's advice. I once was lost (Baquacil) but now am found BBB, lol. Never have I spent so little it maintaining my pool nor had it as easy until I did my research on here with these people's help.
    10k gallon 22' AG Vinyl, 2k got Cartridge Filter, Fresh water, BBB Method baby!
    Casey's Avatar
    SW PA
    10,461
    You're in the right place. You made it to TFP.
    You need a test kit to take control and a bit of knowledge to understand how it works. Pool School is where you will learn everything you need to know. Its overwhelming for some but if you take an article or 2 everyday n read it and ask questions, it's easily digestible.
    Were here for you when you need us to answer your questions. Reading and understanding is key for all of us to work together.
