Thread: Leaking Return Jet Line
    May 2015
    Berkley, MA
    1
    Last year my wife and I had a pool built and was great. I just hooked the DE filter and connections back together and the return line to the jet at the filter is now leaking. No matter what I do including using GE Silicone it will not stop leaking. It also has the grounding connector screw in it... Not sure what the next step.is please help....
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Leaking Return Jet Line
    Welcome to TFP! I don't have an answer to your problem, but if you can upload pictures to Photobucket.com and copy, then paste the IMG code here I am sure someone will have an idea.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Casey's Avatar
    SW PA
    10,418
    Welcome dj. It would help if you could tell us if this is an in ground or above ground pool.
