Thread: Pentair variable pump
    Hey all, I have this pump only a year old and about two weeks ago all was fine with it. Now I try to turn on my deck jets with my automation system and they start to work, then the pump shuts off. I tried any sting rpm, check all I can see with my eyes, and there is no blocks or issues visible. Pump works fine with normal pool mode, only issue is when I try to turn on jets.
    Any ideas? The rpm range I been working with is between 900 n 2500. Doesn't matter where I'm at same issue.
    Using Tapatalk
    Re: Pentair variable pump
    Check to see if an error message is displayed on the pump when it shuts off.
