Thread: Life of sand in a filter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Next year will be our fourth season for our pool and I was wondering what is the life span of the sand in the filter? I am thinking it is probably at its maximum after 3 seasons. We have been closing it and not running it for the winter months here in GA so it hasnt been running for a complete 12 months the past three years perhaps 20 months of the 36 months we have had the pool.
    When I replace the sand how much do I get and is there some maintenance I should do on the head or laterals while its appart and the head is off?
    Thanks for the advice in advance !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Life of sand in a filter
    I have read posts here and on PF that people go much longer than 3 seasons. I have 3 years on mine and still filtering fine. I will change it when I notice a reduction in the performance of the filter.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Dec 2007
    Central New York
    504
    I changed my sand once in 25 years. I just put a new filter in this year only because I was putting in a new pump and changing over to 2 inch lines.
    You will want to change the sand way before the season starts. If you find something wrong and have to order the parts, you can order on line and have time for the parts to arrive.
    If everything was working good, I wouldn't bother to open it.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Hotrod30
    Exactly. Unless you are using biguanide, something else will fail before the sand does. Just change it when you have to get inside the filter.
