Thread: Help! Just paid to have coping regrouted and now coping tiles are breaking!!!
    May 2015
    Spring Hill, Florida
    1
    Hello,
    I am a first time pool owner, however we moved to a home with an existing pool (about 10 years old). We wanted to update are pool decking and the grouting of the coping was chipped out and very worn so we hired a company to re-acrylic coat the decking and re-grout the coping. The used a saw to remove the old grouting and regrouted however, now the grouting has cause several of the coping tiles to chip and break. Also there are cracks all around the pool in the grout. Please help! This was very expensive and the job was done very poorly. It looks really bad and since the pool has been there for 10 years, I don't think we can find the same tiles to replace the broken ones. Does anyone know why this happened? What should we do? Any advice or suggestions are greatly appreciated. Thank you!!!20150517_191915_resized.jpg20150517_191924_resized.jpg20150517_191927_resized.jpg
    Kim Riggans
    Spring Hill Florida1st time pool owner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help! Just paid to have coping regrouted and now coping tiles are breaking!!!
    Welcome to the forum!
    Unfortunately, there isn't much you can do if you can't get the installer to warranty the work. I'm sorry, but I can't say with any certainty what's happening there.
    Essential Links:
    Aug 2014
    Shallotte, NC
    693
    Like Patrick_B, I have no certainty, but it sure looks like either [or both] (1) something is moving or (2) the grout is shrinking as it cures (usually from being mixed with too much water). Grout shrinkage could possibly cause spalling of the tiles, if it adhered tightly enough.
    What does the contractor say?
    Feb 2011
    Petaluma, Ca
    665
    I thought they would use a flexible seal where the coping meets the deck, that's the way mine is, since the pool shell and the deck are independent structures.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
