Thread: Opening pool and vacuuming crud
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I'm vacuuming debris from my Intex 22' pool and this sock fills up with junk pretty fast. If I'm vacuuming to waste, do I even need to use this piece?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Opening pool and vacuuming crud
    How fine is that sack? If there's a lot of crud on the bottom, it's not unheard of to have pine needles slip past the basket and clog up the pump impeller. Something to catch the worst of the big stuff is a good idea, but that looks a bit fine. I expect it would clog itself in minutes.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    That sack is very, very fine. I don't have anything solid in the pool, just green stuff. There aren't any trees around. So vacuuming to waste should be fine?
    TFTest Kits TF-100
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by cfclay View Post
    Yes.
