Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Newbie Starting Third Week of Slam
    May 2015
    Wellington, FL
    10
    i've been fighting algae for a long time with the local pool store recipe to no avail. My pool got so bad I actually had a duck fly in and camp out for an hour two weeks ago.
    That duck sent me a message to find another way and I was so happy to find this site. I started slamming before my Taylor K-2006 kit came and adjusted after being able to test. Pools never looked better but I still have some last remaining green areas on the walls that I'm looking forward to seeing go away. I actually thought the color of my plaster was stained a light green! I'm losing about 4ppm in the OFCT.
    Here's my current water
    FC: Slamming at 20
    CYA: 50
    TA: 80
    CH: 290
    PH: 7.4 (via an Electronic Meter)
    I've been brushing once or twice a day, cleaning the filter every AM to wash out the gray matter, pulled the pool light and trying to keep my POP high. The volume of bleach I'm purchasing has been over the top but much cheaper than the weekly pool store chems which didn't get me anywhere.
    Thanks to all who have posted such great advice here. Looking forward to seeing the OFCT finish in the next week or so and get this into maintenance mode.
    One question: is it ok to increase the FC up to the 30 range in n the morning on work days? By the time I get home it seems to get down to about 13 and I'd like to keep it higher all day.
    PS: I'll try to get the picture thing working when I'm done so I can post before and after photos (duck and all)
    Wellington, FL - 12K gallon IG plaster, 3/4 HP Hayward MaxFLO Pump, Hayward C751 cartridge filter, Intellichor IC20 SWG, Zodiac MX6 cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Newbie Starting Third Week of Slam
    Welcome!
    With 50 CYA, Shock level is 20 and Mustard Shock level is 29. Target maybe 25? And do that at night as well, so it can really attack the algae without having to battle the sunlight. You could also try leaving the SWG on to help make up for the sunlight losses. Not on boost, which will burn it out, but maybe 20 or 30%. Remember to shut it off when doing the overnight loss test at the end.
    May 2015
    Wellington, FL
    10
    Thanks Richard. I'll bump up to 25 in the AM and at night. I forgot to mention that been leaving the SWG on around 40% throughout my SLAM. Once my OFCT passes with it running I'll start turning it off as I'll be getting closets the end.
    My pool store had me hitting it with shock and algecide and told me running the pump for 9 hours would be fine.... I guess you all know how well that works.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Quote Originally Posted by Kraypd View Post
    Yep, and so do you! good job on your slam!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    How does the pool look now?
    May 2015
    Wellington, FL
    10
    Quote Originally Posted by Isaac-1 View Post
    A few weeks ago I would have said awesome. I think that many of us who are new to the site have lost touch with how the pool is supposed to look.
    The water is very clear and enticing but I can now see steaks of green on the walls and just below the water line. The true pool color is coming out which highlights the areas where the algae is still hanging on. Each day the areas of algae are getting smaller and smaller so I think another week or so and I will be done with the SLAM.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Kraypad,
    It just sounds like a tough SLAM, but with progression, so that's a good thing. I would shoot for that very high end of the range each morning if this were mine I promise you. Going 25 or so since you don't have vinyl to worry about. Sounds like you just need even more POP, but hang in there, you'll make it.
    Essential Links:
    May 2015
    Wellington, FL
    10
    Well this am while brushing the pool I had a small snake come swimming out of the skimmer. I've gone from a duck to a snake so I guess I'm making progress.�� Hope to have humans in the pool next weekend. Lost 2ppm over night still with the SWG at 30%. Lowest drop I've seen yet so I hope to switch off the SWG and start my true OFCT by mid week.
    DFW, TX
    24,450
    LOL! Humans in the pool sounds like a good plan!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,423
    Duckies and snakes???????? Are you sure any humans are going to WANT to get in your pool?????????? LOL
    I love the way you write!
    When you are brushing what kind of brush are you using?
    I would look at your skimmer door as well. Some people have found algae hiding on it as well.
    Look at your ladder if you have one. They love to hide algae as well.
    Thanks for the smile this morning!
    Kim
    May 2015
    Wellington, FL
    10
    I'm using a wire algae brush. I ordered a wall whale nylon which comes tomorrow but I think the wire brush is better until the algaes gone. Glad the duck and the snake could lighten up your day. It's been funny for me now that I can see I am on the right track.
    Apr 2015
    Katy, TX
    52
    Good job Kraypd! I know it can be a process, having just finished my SLAM over the weekend. It took me 2 weeks, but I didn't pull my lights out to clean them right away, and I think that slowed my progress. Glad you did yours Sounds like you and I got the same bad pool store advice, be nice to put that behind us!
    Keep it up, seems like you're getting closer.
    Jeff
    Katy (Houston, TX) - 15,000 gallon In Ground free form kidney shaped 30'x15' pool with Pebble surface. Spa - 8' round with waterfall. Hayward Swimclear Cartridge filter (not sure which model though - maybe C3025?). Pleatco replacement cartridges x 4, 1.5HP Hayward Century Pump, Hayward Booster Pump (model 6060). Chlorine tab dispenser, which I won't be using. Polaris cleaner. TF-100.
    May 2015
    Wellington, FL
    10
    Still going with OFCT reading about 3-4ppm loss. Walls are getting cleaner but still see green patches that lighten after brushing and bringing FC back up in the AM. Paying for years of pool store neglect, I wore out my steel brush and had to buy a new one yesterday. POP is hard but keeping at it. Here's the before picture with the duck swimming in the pond.
    Water is clear but clouds up after AM brushing and readings are all in line. Will post them at the end of the slam.
    Jul 2012
    Tallahassee, FL
    30,423
    Quack! She sure looks happy!
    You are very close to being done. Keep up the SLAM levels until you can pass the overnight test. That is the hard one once you get it clear.
    Kim
    May 2015
    Wellington, FL
    10
    Need to rename the thread as week four is underway.
    I've been following the process closely and still seeing daily improvements in the stubborn green spots on the walls. I've increased brushing with the wire brush to twice a day (AM and PM) to try to accelerate things a little bit. I think that there is an area of mustard algae in the shaded part of the pool that I will have to address when the main SLAM is finished. There may also be some black algae which I used to think was dirt. It seems to be lightening but hanging in there. We'll keep an eye on it.
    I pulled apart the light and scrubbed the metal ring down inside and out. There seemed to be a slimy buildup on the underside. Put a new gasket on the light and it's ready to go back in the pool after the SLAM.
    Hanging in there for now but this is lasting longer than I first thought. I'm reminded of the quote about the pool not getting this way overnight so it won't come back overnight.
    Paul
    May 2015
    Wellington, FL
    10
    Thought I was getting close and then this am I noted that I had the heater bypass on. I changed to run through the heater pipes to get any algae that might be in there. When I got home my FC had dropped down to 10 from 24 this AM. My target SLAM is 18 based on CYA of 45 so I've been kicking it a little higher before work to keep it above 18 for most of the day.
    Yesterday it was around 16 when I got home. When the heater was bypassed. Does this make sense that I would have had algae in the heater that would explain the drop?
    Jul 2012
    Tallahassee, FL
    30,423
    OH yeah! Think if there was ANY water in the pipes it could get yucky. I am glad you found it now.
    Good job!
    We will need to add cleaning the heater when someone is doing a SLAM.
    Kim
    May 2015
    Wellington, FL
    10
    Thanks Kim. Good to know I'm not going crazy. I FINALLY PASSED MY OFCT AM!
    I still have an area of mustard algae in the shallow shady area and what I believe are the last remnants of green organic staining. Thought this was algae but wih the test results I'm guess it's organic staining. Brushing seems to have nearly completed this.
    For the mustard algae I have to raise the FC to shock level for 24 hours so I think I'll continue at regular SLAM until the weekend when I can adjust FC and brush frequently. I plan to cycle my valves and run through all of my piping (skimmer, main drain, heater etc.) to make sure I nailed it all. I also plan to put the light back in before the mustard shock just to make sure nothing is on the housing.
    Here are my full numbers from this AM:
    FC: 20
    CC: 0.5
    OFCT: 0.5
    PH: 7.5 (via Milwaukee electronic meter)
    TA: 90
    CH: 300
    CYA: 45
    SALT: 3800
    BORATES: <50
    Jul 2012
    Tallahassee, FL
    30,423
    Have you tried "sneaking" up on the stuff on the bottom with a manual vacuum? That may be the way to get it out.
    I would have a sock in the skimmer AND wash the filter right after you do it to make sure it does not sneak back in.
    Kim
  20. Back To Top    #20
    Mar 2015
    Baton Rouge, Louisiana
    92
    Removing snakes and Frogs from your pool isn't normal daily maintenance? Haven't had a duck yet.
    26000 gallon Kidney shaped gunite pool. Older pool with deep dive well, nice diving board and tall slide. 31" Hayward pro sand filter with Pentair 1.5hp pump. Testing with the TF-100 plus test kit. Using a Dolphin Nautilus pool cleaner robot, next to bleach, my pools best friend.
