Results 1 to 20 of 20
Thread: Was Green - still a little cloudy
    Let me start with saying I love this forum and the BBB system. I have been doing pretty well for several years AFTER giving up on the pool store and all their chemicals.
    I went through about a week at shock level (around 14). The water was very green, and within the first few days it improved a lot. But it hasn't been improving the last 2-3 days and still a little cloudy. Scrubbed the sides, vacuumed a few times, and cleaned filter several times. I let the FC come down to get a good PH reading...Here are my numbers:
    Vinyl above ground 7500 Gal pool with cartridge filter
    5.5 FC
    O CC
    7.2 PH
    95/100 TA
    20 CH
    40/45 CYA
    Should I go back up to shock level and wait longer for it to clear up or do something else? Any advice would be appreciated.
    38,371
    Re: Was Green - still a little cloudy
    You have not passed the clear water criteria to stop the SLAM process.
    Is the pressure rising in your filter?
    Please add your pool details in your signature.
    I agree but also wanted to get a good PH reading. Should I adjust PH before going back to SLAMing? I have an aerator hose that does it pretty quick. Borate is around 15 (based on test strip which is all I have for that measurement.
    The pressure is only around 2.5psi, it never really goes very high. Don't think I've ever seen it above 5 but I don't watch it very close because it never seems to change much regardless of a "dirty" filter. I often wondered if that is part of my issue with not getting "crystal" clear? The filter cartridge is 2 years old, I used an old one for the first few days to get most of the junk out then put this one in which seems to be in pretty good condition. At least it looks decent and white. Anything I can do with the filter before going back up to shock level?
    I'll have to find the signature section and add the info later...thanks!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You can wait to adjust PH after you have passed the SLAM. In settings you can update your signature.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Is it possible I have a filter issue since the pressure isn't going up and the filter is running 24/7 and I passed the overnight FC drop test? Or just get the FC back up and keep SLAMing???
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Gyro_head View Post
    You did not pass the part of the SLAM criteria for your water to be clear, so you have not passed the SLAM.
    Do you have a good flow of water coming out of the return? If you do there is probably nothing wrong with your filter.
    The better your water gets the less your psi will rise.
    Lisa
    Yes, good flow through return. Was worrried that maybe small particles are bypassing somehow and recirculating. But as you stated, I did not pass the "clear water" so I am bringing it back up to shock level now. How long should this take before considering filter issues?
    7500 Gallon
    Above ground
    2 speed Jacuzzi brand pump
    50 GPM, 50 SqFt filter cartridge
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I cannot say how long it might take to get the water clear since it really varies. As long as you have good water flow from the return then I would not worry about the filter. Just backwash when the pressure rises and you notice lower water flow from the return.
    Get everything back hop to SLAM level and we can go from there. If you want to upload pics to photobucket you can copy then paste the IMG code here.
    Lisa
    I don't use photobucket but will give an update when I see some progress, thanks for the help!!!
    7500 Gallon
    Above ground
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome.
    Lisa
    38,371
    What brand and size are your pump and filter?
    FYI: How To Post Pictures tutorial.
    Jacuzzi brand 50 GPM 50 SqFt filter cartridge. I added 140oz 8% bleach last night and the FC is at 17.5 and 0 CC now. Lets see if these pictures show up...Its hard to see how cloudy the water is, I think the light makes it look worse but its definitely not good yet.
    https://www.flickr.com/photos/132553...n/photostream/
    Sorry, I can't get the picture to show up using Flickr, only the link.
    7500 Gallon
    Above ground
    Update:
    Still SLAMing, FC did drop to 11.5 today because I was away, but I just added bleach to bring it back up To 18 FC. The water is looking better but still not crystal clear yet. The pressure hasn't changed from around 2.5 PSI
    7500 Gallon
    Above ground
    Still cloudy...seems like I'm not making progress and this shouldn't take this long to SLAM. Any suggestions? Any way to rule out the filter system not catching the small particles? Pressure stays at 2.5.
    7500 Gallon
    Above ground
    38,371
    That pressure seems surprisingly low.
    Is the gauge working? Does it go to zero when the pump is off? Do you feel good flow out of the return jets?
    I agree on the pressure but it does go to zero when off and it goes to 10-15 when I switch the pump to high speed. I only use high speed for vacuuming.
    7500 Gallon
    Above ground
    38,371
    OH ... well of course it is that low on low speed ... you did not have that it was a 2-speed pump in your signature.
    You should use high speed pressure to check when you need to clean the filter.
    Oh, didn't know that, always learning something new here! Also forgot to say that the flow feels normal too (low speed). So running on low during normal filtering and SLAMing is correct? And on high for vacuuming and to check the rise in pressure occasionally? If a clean filter is around 10/12 psi, at what pressure would you say the filter should be cleaned?
    Based on all of this, do you think there is a possibility of a leak in the filter system? Or just keep SLAMing? Seems like it's not clearing up. I had no FC drop overnight several days ago already.
    I will update my info.
    7500 Gallon
    Above ground
    38,371
    Well is the clean pressure 10 psi or 12 psi? We recommend backwashing when the pressure rises 20 to 25% over the clean pressure.
  20. Back To Top    #20
    It runs clean at 12.5psi. I just cleaned it to check, it wasn't very dirty but I noticed the top of the filter was not tight around the plastic support that the filter sits on (not sure what it's called). It's the part that directs the water after the filter down to the outlet. It seems like this should be tight otherwise water can bypass the filter pleats through this gap. I took a piece of small diameter vinyl tube and packed it into this gap...letting it run overnight to see if this helps.
    I am also keeping it a shock level a little longer.
    7500 Gallon
    Above ground
