Results 1 to 8 of 8
Thread: TA test affected by FC ?
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Question TA test affected by FC ?
    Hello,
    Before slaming, my TA was 90 ppm (i count 9 drops)
    Now, at FC of 5.0 i only count 5 drops for a TA at 50 ppm .
    I dit not refil the pool, nothing. I only add this morning 1kg of borax to ajust pH
    I always test in 25 ml, add 2 drops of reagent 7, 5 of reagent 8 and after i count each drops
    Also, i have some reagent left from last season, and i got the same result (5 drops)
    There my actual result:
    FC= 5 ppm
    CC=0
    pH= 7.5
    TA=50 ppm
    CYA=0
    Thanks helping me
    Sorry for my english, je suis francophone
    I live in north, no ice in my pool since may 1 !
    Stylus aboveground swimming pool 45 000 liters
    18' round and 52" high with sand filter
    38,354
    Re: TA test affected by FC ?
    FC level will not affect the TA test. Very high FC levels may change the colors, but the test is still valid.
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Ok Thanks , i dont understand my result. Any hint?
    38,354
    one of the tests must have been wrong.The TA can have static in the bottle giving higher result, you should wipe the tip between drops.
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    I wiped the tip for this morning test, same result .
    I forgot to tell my pool have 30 ppm of borate.
    Those borate may interfer??
    I performed this test all last season, but this is the first year i use borate ....
    38,354
    So the first test must've been wrong. The borates will not have an impact.
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Finnaly i got my water analysed, frome a friend, with taylor reagent .
    I got the same relsult: 50 ppm
    My test was correct, now i just have to manage how i could lost 40 ppm........
    You didn't lose 40 ppm of TA, the first test result must have been incorrect.
