Results 1 to 12 of 12
Thread: Cleaner Tube Keep Getting Clogged!
    Feb 2014
    Leander, TX
    33
    Angry Cleaner Tube Keep Getting Clogged!
    This is my 2nd year owning my pool. So far, no major issues! I have noticed, however, that I'm having to clean out the filter/strainer that is in the end of the pool cleaner hose that connects to the side of the pool, where the water is pushed in to the cleaner to make it move. I'm over quota and I can't delete pictures or add pictures, so you'll have to use your imagination!
    I'm not sure what's going on. It seems to be an inordinate amount of gunk clogging it up. Grit, bug bits, and grass, etc.
    Any thoughts are appreciated!
    23k gal IG pebble, 48 sq ft Pentair FNS Plus DE filter (FNSP 48) 96 GPM, 1.5 HP WhisperFlo pump, Kreepy Krauly Legend Robot.
    Pool was built in 2011, in Central Texas (Leander, TX)
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Cleaner Tube Keep Getting Clogged!
    You can upload photos to photobucket.com and then copy the IMG code and paste it here.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    You talking about something like this? Your booster pump is plumbed after the filter, right? You should have fresh, clean water going back to that. If it's plumbed right, that stuff would have to be getting through or around your filter.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Feb 2014
    Leander, TX
    33
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Still doesn't make sense that it has stuff getting to it. How is it plumbed at the pad?
    38,428
    Sounds like the cleaner is not plumbed after the filter.
    Feb 2014
    Leander, TX
    33
    I'm not sure...I'm a relative newb Here are some pictures of the whole setup: https://drive.google.com/file/d/0Bxi...ew?usp=sharing
    38,428
    Well, booster is definitely plumbed after the filter, so I am not sure. Clean it out and see if the problem appears again. This could happen if you were running the filter in Recirculate mode to bypass the filter and also ran the booster for the cleaner.
    Feb 2014
    Leander, TX
    33
    I have to clean it out every day or the cleaner doesn't run (pressure is too low because of the clogging). Something is askew, I just don't know where to look...maybe I need to clean out my DE cartridges/filters and just start with new DE and stuff.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Take pictures of the pump setup to verify where it is plumbed. If it is plumbed after the filter, something in the filter may be broken.
    38,428
    Well, then something is wrong with the filter. Time to pull it apart and inspect everything: DE Filter Cleaning Tutorial
    Feb 2014
    Leander, TX
    33
    I reckon that's where I'll start! Thanks...
