Thread: Dead algae
    May 2015
    Schriever Louisiana
    1
    Dead algae
    I have a 18 foot round above ground pool salt water with dead algae what is the best way to get rid of it should I let the filtering system get rid of it the water is crystal clear the vacuum it up and made things worse
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Dead algae
    If you are sure it's all dead a combination of brushing, vacuuming and pump/filter time should get it.
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Dead algae
    Welcome to TFP. As Tim said brushing, vacuuming and running the filter will clean it up.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
