Results 1 to 8 of 8
Thread: Chlorine consumption seems off
    lmnconn's Avatar
    May 2014
    Missouri
    35
    Let me post my numbers first:
    FC. 8.5
    CC. 0
    Ph. 7.8
    TA. 100
    CYA 70
    CH. 180 (Using Taylor test kit)
    OCLT done several nights and may use .5 at the most, so things seem good there. Water is sparkling, crystal clear. During the day I wil lose 4-5ppm chlorine. This seems like a lot of loss considering how high my CYA is. I am draining and adding water to try to lower my CYA. I like to keep it around 40. (I am testing before adding a bunch of new water, then retest once I'm done adding water and add chlorine to bring it to proper level overnight). Last year, keeping CYA at 40, I would only lose 1-2 ppm on full sunny days. I know my Ph is on the high end of the good range, it just shot up from a hard rain yesterday. My well water Ph tests at 7.2, so I will retest Ph after I'm done adding water today and see if I still need to lower it a little. Am I being overly critical here, or could I have some kind of problem brewing?
    St. Louis, MO, 25000 gal, 16x32 lagoon, vinyl, sand filter, Hayward pump, chlorine, install complete 9/12, Taylor TF100 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Chlorine consumption seems off
    That is a very normal FC loss. Nothing is wrong. You know the PH is a bit high and you are good to go.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    With a CYA of 70 your at the the recommend lever for FC.
    http://www.troublefreepool.com/conte...art-slam-shock
    How are you measuring the CYA? Lighting (Bright sunny/cloudy/indoor lighting) will have some effect on being able to see the dot if your testing your self.
    Pool is clear, your maintaining the proper chlorine level. Enjoy your pool. The chlorine loss is the chlorine loss. Are you adding every day? You don't want to go below 5 on your FC, otherwise algae can take hold.
    lmnconn's Avatar
    May 2014
    Missouri
    35
    I check my pool every day, sometimes twice a day if doing OCLT. I do add chlorine every evening to keep it in proper range for CYA level. When I check CYA, it's been late afternoon sun. I would rather it be brighter sun, but we haven't had any sunny days on the weekends when I'm home lately. This is the 3rd year for our pool and it's never used that much chlorine during the day. Just had me a little worried. I thought maybe I was getting old chlorine that the store had leftover from last year, but it always comes up to my target when adding according to Pool Calculator. I would think if it was old stuff, it would take more to raise my FC.
    lmnconn's Avatar
    May 2014
    Missouri
    35
    I must have had some of last year's chlorine because I'm buying the same stuff now and back to only losing 1-2ppm each day. I guess it's good to know my pool so well, but sometimes I get a little paranoid when something is out of the norm.
    Jun 2014
    15,139
    Well then, now it's time to enjoy your pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Quote Originally Posted by lmnconn View Post
    I'd say you now have a confirmed case of sparklypoolitis.
    Just think of those poor schmucks who still rely on the pool store and weekly testing. They haven't got a clue what's going on in their water. This is a perfect example of why self-testing is the way to go. You knew something was wrong right away. You didn't have to wait for it to turn murky and green.
    lmnconn's Avatar
    May 2014
    Missouri
    35
    I'd love to get in and swim, but we've had excessively rainy and cool weather this past month. Water is still too cold for me @75. I like it in the 80's. I'm hoping to get on my big pool float today. It's one that keeps me pretty much up, out of the water. At least I'll kind of be in it!! This is the first weekend in 5 weeks where we aren't getting rain. And Sparlkypoolitis is such a good thing to have!!! So glad I found this website/forum!!!
