Results 1 to 13 of 13
Thread: SLAM in Process - Need Help!
    May 2015
    Lafayette, IN
    4
    Hello and thank you for any help in advance!
    We bought a PermaSalt pool last year and decided to convert it to chlorine at the beginning of this season using the method on the website. Due to some family reasons, the pool got in bad shape (algae!!) towards the end of the season. We ended up closing it green knowing we would have some work when opening it in the spring.
    Well, I did lots of research on this site, purchased the Taylor K-2006 tester, and took out the PermaSalt tube and replaced it with normal PVC.
    I used the test kit to do all the initial tests to see where we started they were:
    FC: 0
    CYA: 0
    PH: 7.1
    TA: 140
    Did some adjusting on the PH to settle at 7.2 and then added the stuff needed to target a CYA of 40. Then started the SLAM process using PoolMath with an FC target of 16. Last weekend spent two days of testing FC every 1-2 hours and adjusting. Since getting a better handle on how quickly the FC changes (hasn't been all that sunny lately) test it 2-3 times/day. Been brushing, vacuuming, and backwashing daily.
    Here are the couple tests I ran yesterday, a week after the process:
    FC: 25
    CYA: 30-40 range
    Here's where I need help. It doesn't seem like much progress is being made. At this point, I was hoping to at least have the algae turn gray-white and beginning to die! I've added some pictures (all taken with grey skies) of what the pool looks like this morning. The algae always seems to settle in this same spot in the middle of the pool.
    Also, the weather in Indiana has been a little all over the place. The water is still in that 55 degree range. Could that be slowing the process?
    24' X 52" Round Above Ground: 14,900 Gallons
    EcoKleer 26" Sand Filter by Waterway
    EcoKleer 1.5hp Pump & Motor by Waterway
    Vinyl Liner
    Dolphin Nautilus Robotic Pool Cleaner
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: SLAM in Process - Need Help!
    First let me welcome you to TFP. Congrats on your test kit and adjusting everything to proper levels before SLAM process. If you think the CYA is closer to 40 then target that.
    The hard thing during a SLAM is POP (pool owner patience). I promise you if you keep FC up and brush lots as well as vacuum you will start to see a change.
    What is your CC?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    It's good that you didn't use the "system" for very long. The big issue is that PermaSalt uses copper and silver which are both very slow at killing things. Those metals will always be in your water, but levels will slowly go down through backwashing. Once you get past the SLAM you want to be careful not to let your pH get too high 7.8+ or the copper in the water can stain.
    As Lisa said clearing up takes patience. Stick with the SLAM. Test and adjust back to shock level as often as possible.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    If there's any organic debris hiding beneath the murkiness, that will slow you way down, and rob a lot of bleach.
    Bleach is an oxidizer - think flameless combustion. It's trying to burn up leaves and twigs and whatever else that might be in there that could be considered combustible. Try vacuuming blind. If the filter starts loading up and pressure skyrockets, you know there was something down there.
    Apr 2015
    Katy, TX
    52
    Good job, and welcome. You're on your way, just keep that shock level as much as humanly possible, you'll get there.
    Jeff
    Katy (Houston, TX) - 15,000 gallon In Ground free form kidney shaped 30'x15' pool with Pebble surface. Spa - 8' round with waterfall. Hayward Swimclear Cartridge filter (not sure which model though - maybe C3025?). Pleatco replacement cartridges x 4, 1.5HP Hayward Century Pump, Hayward Booster Pump (model 6060). Chlorine tab dispenser, which I won't be using. Polaris cleaner. TF-100.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    My pool looked similar yo your pics you added when I started. Feel free to look thetheMy SLAM process linked in my signature. You can do this!
    Lisa
    May 2015
    Lafayette, IN
    4
    Following up a week later....still not much progress made. It's looking more clear, but still getting the green circle in the middle after things settle.
    Tests last night were:
    FC: 23.5
    CC: 0.5
    CYA: 30
    Trying to stay patient, but my husband is starting to challenge the method. I think we are at about 45-50 bleach bottles in (8.25%) and now two full weeks (on weekend #3).
    Thank you for all the encouragement!! I'll try to get some pictures in here later today since the sun is (finally) shining.
    Vinyl Liner
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Lots of patience. Sorry your husband had his doubts. Mine did too. It was great to prove him wrong.
    Lisa
    May 2015
    Lafayette, IN
    4
    That's what I'm looking forward to most of all.
    Second, is the sparkling pool we had last year.
    Vinyl Liner
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    It is always great to prove hubby wrong.
    Lisa
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Right! Hey, wait, I'm a hubby. Awwww.
    May 2015
    Lafayette, IN
    4
    But you're a believer - so all is good!!
    Vinyl Liner
    DFW, TX
    24,497
    Ppsshhhewww, that was a close one! . I am already trained!
