Results 1 to 9 of 9
Thread: Downsides to a SWG?
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Cool Downsides to a SWG?
    From what I have read, there doesn't seem to be a downside to using a SWG other than initial system cost. Maybe the fact that you need to clean the plates.
    I am looking to buy a SWG for under $100, so initial cost isn't really even a downside.
    http://www.amazon.com/Intex-Saltwate...ct_top?ie=UTF8
    What other downsides are there, if any?
    How long on average will it take for the SWG to pay for itself ($100)? I know, lots of variables, but rough guesstimate.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Jul 2007
    Suwanee, GA
    528
    Re: Downsides to a SWG?
    Downsides can be:
    1. Increased electricity usage
    2. Salt costs, I usually have to add 2-4 per year.
    3. Salt water is not so good for the environment. When draining pool, backwashing and splash-out. The grass under and downhill from my overflow struggles.
    4. Additional part in the plumbing to cause trouble.
    I can't think of any others. For me, it's not so much for the cost savings but for the convenience.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Potential downside could be someone who assumes that the pool is now self-maintaining and they fail to monitor and treat the water as needed until problems arise.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    For me, it's just one more thing that can break. It's pretty hard to get simpler than pouring bleach out of a jug.
    Running a search on "SWG not producing chlorine" yields a phenomenal amount of threads here.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    The main downside I see is kind of a combination of Skippy & Richards comments. SWG are wonderful when they are working. In my opinion you start having issues you usually discover it because your pool is going green. Then there is a short laundry list of "what could be wrong". Power supply, control board issues salt level, and several other issues float to the top.
    I like the tank of bleach sitting next to my Stenner pump. I look at it each day and can see the chlorine level going down. If I'm lazy and skip,a,day testing I've seen that it had had its ration of bleach.
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Salt Water can also erode soft stone commonly used around pool decks in some parts of the country (Texas comes to mind).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    I love my SWG. As long as you test regularly and know how to dose with bleach as needed you should be fine. I use bleach when the water is cold and when the FC drops as demand increases due to extra swimming, getting hotter and sunnier, etc while I wait for the SWG to catch up. It is very important not to let the FC fall below the minimum level on the Chlorine CYA Chart. If it does then algae will start growing.
    May 2015
    Pooler, GA
    311
    I went ahead and ordered my SWG. Thanks for the push everyone!
    TF-100
    Helpful Links
    Jul 2007
    Suwanee, GA
    528
    You won't regret it!
    One thing I forgot to mention, @Issac-1 reminded me. The combo of chlorine and salt has been not so kind to my deck fasteners. I've gone through galvanized nails, and two sets of deck screws on my stairs...
    Gary
