Thread: Replacement pump and calculation advice
    May 2015
    Columbus, Ohio
    2
    Hello,
    My Hayward Super Pump 1HP burnt up after just 4 years of service. I've visited my local pool shop where they are recommending moving up to a 1.5HP.
    I've done a lot of calculations over the last few days on feet of head, GPM etc., and I'm just not sure what to go with. My pump/filter sit up from the pool with about a 4 foot difference in height, and sits back about 75 feet from the skimmer and floor drain. I've got 1 floor drain, 1 skimmer, 3 returns, 4 deck jets. I'm also plumbed for a slide for the future. Additionally I have a Hayward Heater plumbed in.
    Some pool statistics:
    20x40 Pool with 33,000 gallons
    Approximately 80 feet of head
    1 1/2" Plumbing
    244T 300lb Hayward Sand Filter
    Is it still the best to calculate how many GPM I need in order to turn the pool water over? I read the "Determine Pool Pump Runtime" and it sounds like it may be a good opportunity for me to put in something with variable speeds. Where I live I usually run my pool continuously to keep it clean.
    I figured I'd get way more out of my 1HP Super Pump. Is Hayward still a decent pump?
    What would be a good way to control pump on time? Right now the pump is just wired to a manual switch?
    Do I really need to upgrade to a 1.5HP?
    If I am doing these calculations right, it seems I need larger plumbing if the goal is to hit 68.75 GPM in order to turn the pool over in an 8 hour period. Is the calculation on Inyopools "How to size a pump" accurate?
    Thanks for your time...
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Replacement pump and calculation advice
    If you read the pump run time article, you should know that GPM and turnover don't really matter and calculating GPM is a waste of time.
    You could just replace the pump motor. Less expensive and less work. For a 1 HP SuperPump, a STS1102RV1 is the motor you would want.
    Mark
    Getting a larger pump is just a waste of electricity.
    Getting a two speed pump (or motor) would save you a great deal on electricity. A variable speed is unlikely to ever pay back it's higher up front costs.
    May 2015
    Columbus, Ohio
    2
    Thank you both for your replies.
    1. Are there some sort of timers that would switch the motor from one speed to the other at certain times?
    2. I noticed that that mount plate is melted from the other motor - can I buy just this part?
    3. Is there a recommended place to go for all these things?
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,741
    1. Yes - http://www.amazon.com/Intermatic-T10...ords=T104+T106
    2. Yes - http://www.amazon.com/Hayward-SPX160.../dp/B00407SLOG
    3. Amazon, InyoPools, PoolSupplyWorld, Poolcenter plus many others. Google shopping does merchant reviews which is one way to choose a reputable merchant.
    Mark
