Thread: Not getting water flow
    My 3rd or 4th year opening the pool.
    Just hooked up my pump to sand filter yesterday and having an issue. I see water climbing the hose from the pump to the sand filter but not getting any water to come out no matter what setting I have on the multiport. The glass in the multiport gets alittle water in it but not much. I'm just trying to run the filter to Waste and nothing come out of waste port. The flow of water in the hose from pump to sand filter looks alittle strange. I can see the flow going into the sand filter but unless my eyes are deceiving me there also looks like a flow of water in hose going back to pump.
    I've checked connections and all look sealed as usual. I put a hose in the piping that leads back to skimmer and water comes out of it.
    I'm not sure what to check next. Thoughts ?
    3rd yr pool owner, 16x36 oval IG,Sand Filter, Vinyl liner, 3/4 HP hayward pump,loop loc cover
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Not getting water flow
    I've seen fuel hoses separate internally and the pressure gets between the layers and forces the internal layer to close off. I don't see why it couldn't happen to pool hoses. Otherwise, I'm stumped, too.
    I'm not sure of the exact fix but I tinkered with the pump and filter alittle more and finally getting normal flow . maybe some blockage in the line finally cleared or air. Phew!
