Thread: I goofed a bit on my TA. How bad off am I?
    May 2013
    Ottawa, On, Canada
    32
    So i went to the pool store as I needed CYA and I knew my Alk and Cal were a bit low. So I let them test my water and they agreed, Alk and Cal were low. They suggested 8 kg of Alk + (Baking Soda), and I bought it added it and forgot to check their math.... oops... Well it turns out they miss read my TA (it was 60 and they read 30), and they had their targe set to 120 where as I had a target of 80-90. Anyways now my TA is 140
    So the question is. I know it's high, but is it too high? Will it come down on it's own? If my PH is staying more or less stable is 140 ok? I'd really like to avoid the the whole adding acid and aerating thing if I can.
    27' AG Round (~17000 Gallons or 64000 L)
    Hayward 1.5 HP Power Flo Matrix Pump (2 speed usually run 6hrs high 18hrs low)
    Hayward CC150CAN XStream Cartridge Filter (150 ft^2 120 GPM)
    Hayward AquaTrol SWG
    Installed April 2012
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: I goofed a bit on my TA. How bad off am I?
    It should be fine in your pool and drift down on its own.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Plenty of people have fill water higher than that. Your pH may rise faster than it would if TA were in range. When it does, just add acid and TA will come down over time.
    You know your vinyl pool doesn't need Calcium, right? If you bought some to add, you wasted money.
