Thread: Pressure Release Valve
    I'm pretty sure it's called the pressure release valve that's what is connected to the end of my cleaner hose into the wall. The valve has a filter screen, and from my guess in the way it's positioned it's not screening in from the cleaner but the opposite direction. This screen gets clogged with debris regularly like I would several times a day. Where is this debris coming from, the cleaner pump? How does debris get in there?
    Thanks
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    Re: Pressure Release Valve
    It is typical for a pressure side cleaner to have a valve such as you describe. If debris is accumulating on the screen then something is wrong with your filter, or you are running the pool in recirculate mode, rather than filter mode. When in filter mode the filter should not allow any debris through that is large enough to be seen without a microscope.
    JasonLion, when you say something is wrong with my filter do you mean pool cartridge filter?
    https://www.youtube.com/watch?v=NBfTdu5QUbM
    This YouTube video shows the part i'm speaking of. The little screen that is in the quick-disconnect for my Polaris has this small screen. Its constantly getting clogged with debris, I have no idea where the debris is coming from as I do not think it's coming from the actual polaris
    If debris is getting into the small polaris valve screen between times when you clean your main pool filter, then yes there us something wrong with the main cartridge filter. The main cartridge filter should block all visible debris. The only time debris might get past the main filter and accumulate in the small polaris screen is when you remove the main filter for cleaning.
    Quote Originally Posted by JasonLion View Post
    I only clean the filter cartridges 2 times a year and most recently 1 month ago. The small polaris valve screen has been clogging up regularly before and after I did the recent cleaning. I'll need to trouble shoot how and if this debris in the small valve screen is coming from the pool filter.
    Just as a point of reference. I have 3 separate pumps, Pool filter, pool cleaner and waterfall. So in essence is debris thats being processed through my pool filter making it's way into the cleaner pump and through there toward my actual polaris cleaner?
