Thread: Unibead question
    May 2015
    Ohio
    13
    Unibead question
    I recently bought a seaspray allure 52" 24' round pool off a lady that purchased it about 7 years ago. I bought a unibead liner for it, the wife took it down while me and a buddy was removing the deck. So I don't know how exactly came apart but it appeared to be a beaded liner because I have a bead receiver track. My first attempt I put the j hook into the bead receiver and started to fill up the pool and after about 5 inches of water the liner came loose. After looking around the internet I have decided to not cut the j hook off, and hook it to the top of the pool wall. Do I need to put the metal stabilizer rail that was on top of the bead receiver track over the J hook?
    Casey's Avatar
    SW PA
    10,444
    Re: Unibead question
    Yes, you do. That metal bar will keep the j hook in place.
    May 2015
    Ohio
    13
    Thanks for replying
    I've also read to run shop vac while filling until water level is above cove then its not needed anymore..correct?
    Allure52 24' round AGP 13,000g/sand filter/Intex SWG....Taylor K2006
    Casey's Avatar
    SW PA
    10,444
    Yes. That liner will be pretty snug too. Start at 12, 3, 6 and 9. Then 1, 4, 7 and 10 til it's on. That will ensure it's set properly.
