Results 1 to 7 of 7
Thread: Air in basket
    Aug 2008
    North of Tampa FL
    14
    Air in basket
    I've tried doing a search but I guess I'm not using the right terms.
    I went out to brush the pool today and noticed that one of the returns wasn't working. I checked the pump and the basket has a lot of air in it. One of the other returns has air bubbles coming out(the one furthest from the pump) while another is running at full force (the one closest to the pump.)
    I asked DH to check and he played with some valves and accidentally drained some water out of the spillover-spa. Then he had to take DS to baseball game.
    Well, spa refills with super cloudy water, so now not only do I have air I have a cloudy pool.
    I checked for air leaks, putting water on all the joints looking for air bubbles but found nothing. What do I do now?
    14188 Marcite pool. 1/2 hp pump Hayward cartridge filter. SWCG Goldline T-15 Turbo cell. Spillover spa. Birdcage.
    Aug 2008
    North of Tampa FL
    14
    Re: Air in basket
    Now it's my turn to go to baseball game. More pics of pool
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Air in basket
    Sounds like a suction side leak and likely culprits are usually the seal for the pump lid basket or valves. Remove the pump lid, make sure the seal is completely clean and put a little plumbers greese on it. It sounds like you may have already checked the valves by putting water on them.
    Otherwise is could be a broken pipe somewhere. Also, a diry impeller sometimes will cause those symptoms.
    Others may have some more ideas.
    Mark
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Air in basket
    Hi Jenn - welcome to TFP!!
    Mark has given you good advice! There's an article in Pool School about leaks here
    If you have any trouble locating and fixing the leak, Mark, I and the rest of the members will be here to help
    I wish you well with fixing this problem and sincerely hope that it's the only one you ever have
    Luv& Luk
    -Ted
    Aug 2008
    North of Tampa FL
    14
    Re: Air in basket
    Thanks. Off to check. I hope it's something simple. We replaced the pump recently. Maybe it was a bad install.
    Aug 2008
    North of Tampa FL
    14
    Re: Air in basket
    Okay, we think we found the issue. DH cleaned the salt cell but didn't fully tighten it. We tightened it up and the pump basket is air free.
    Thanks for the help
    P.S..I was out there brushing because I have some stains in the pool. I put some Vit C tabs on one and let it dissolve while I puttered with the pump. When I came back there were black spots where the Vit C tabs were. Oy.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Air in basket
    The SWG is on the return side of the plumbing so I don't think it would have anything to do with air in the pump basket which is caused by a suction side plumbing leak. If the SWG had a leak, it would spray water because it is under pressure and you could easily tell. Something else must have solved the problem.
    Mark
