Thread: New agp site question
    Apr 2013
    Argyle, TX
    77
    Hi
    I have just purchased the pool in my signature and have a question about the site where it will be installed.
    The site has had 2 different INTEX 18' Ultra Frame pools over that last 7 years and the last one was just taken down 2 weeks ago.
    The ground seems to be very soft/damp in this area and I need to know if this will be a problem installing a new pool.
    I will be using a installation company that comes highly recommended by a local multi store pool dealer
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
    King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: New agp site question
    Welcome to the forum!
    That's probably a good thing then. If it's not terribly wet/moist there, it should be alright.
    Essential Links:
    Apr 2013
    Argyle, TX
    77
    Here in the DFW area we have had massive rains and it is very moist.
    I have thought about spreading some lime to help dry it out.
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Casey's Avatar
    SW PA
    10,444
    Your installer should be able to install with minimal issues. They will set the pool post on pavers so it doesn't shift.
