Results 1 to 10 of 10
Thread: Aqua Trol control with flow switch?
    Is there a way to set the the Aqua Trol to turn off when the flow switch senses no flow?
    It is an RJ model but I added the flow switch bc I can't use the built in timer to control pump.
    As it is right now, the flow switch will keep the aqua trol from turning on the cell but it doesnt shut it off when the pump cuts off.
    Any suggestions?
    Thanks!
    24' x 52" Round AG Pool, Hayward Aqua-trol SWCG, Hayward Pro Series High Rate Sand Filter, Hayward Power Flow LX Pump 1HP 60GPM, Hayward H100ID Heater.
    38,251
    Re: Aqua Trol control with flow switch?
    Are you asking if the flow switch can turn off the power completely to the SWG? Not easily. The flow switch is just meant to stop the SWG from generating when there is not enough flow.
    Ideally the SWG should be powered off the same timer as the pump.
    Just stop generating. The pump is 220v and the outlet on the aqual trol is 110v.
    I was hoping that adding the flow switch would stop the generation but its not.
    Does anything need to be changed on the aqua trol since it is a RJ unit?
    38,251
    Not sure. The other version of the aqua trol includes a flow switch. You may want to contact Hayward, or maybe they will chime in on this thread.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    The flow switch only shuts off power to the cell. It does not hurt the unit to have power all the time.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Quote Originally Posted by Hayward Pool View Post
    I dont think it is shutting the cell down. The display doesnt show no flow and there are bubbles coming out of the return jet.
    Oct 2014
    Elizabeth
    426
    This is confusing. If the pump is off and the unit is not showing no flow, the flow switch may be bad. Unplug the flow switch from the unit and see if you get a no flow light. If yes the flow switch is bad.
    Hayward Pool Tech
    38,251
    I think the question if you can answer it, Hayward, is whether the RJ version can just have a flow switch added and have it work or if the software does not support it. The RJ does not come with a flow switch.
    I have an Aqua Trol RJ and they dont require a flow switch. Flow switches are only needed on the horizontal mounted units so the gas that is generated doesnt back up into the filter or pump. On the RJ model the gas escapes to the pool via the return jet, thats the bubbles you are seeing.
    24' ABG 15,000 gallon. Installed 2005, AquaTrol SWG installed 2015 Pentair 1.5hp pump, 200#sand filter
    Blue Springs, Mo.
    38,251
    We are well aware of that. The question is, can a flow switch to added to a RJ controller if the cell is NOT mounted at the return jet.
