Results 1 to 16 of 16
Thread: How bad does it look? Where do i start?
    May 2015
    Roseville, MI
    10
    Bought the house in September, and the pool wasn't opened at all last year. I am completely new to this and am looking to be pointed in the right direction to open the pool up right and not burn my money in the process. Thanks for any advice you can give me, it's around a 22k gallon pool with a sand filter setup. http://i.imgur.com/8GqpMYT.jpg
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How bad does it look? Where do i start?
    Welcome to the forum Detroit!
    You will need to complete what we call a SLAM process on the pool to kill the Algae. It requires raising the chlorine level up, and keeping it up until the pool is cleared. You can begin reading about that process by clicking the links in my signature. You need a proper kit, and a little knowledge which you can acquire here. Others will chime in with help as well. Enjoy your time on TFP.
    Essential Links:
    May 2015
    Roseville, MI
    10
    Thank you Patrick! Gonna order a tf-100 tonight and go through all of the links.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    Great picture. We love swamp pictures.
    Before anything else, you need to know where you're at chemistry-wise. Pool store testing doesn't cut it, nor do test strips. And most test kits sold by stores won;t read chlorine high enough. There's a lengthy writeup in Pool School, but you could always skip it and head straight for TFtestkits. get the XL option now, you'll need it for that swamp. Yes, it's a chunk o'change, but it will save you at least that much if it keeps you out of the pool store. And no, I don't get a kickback for endorsing it, either.
    While you wait for test results, start dredging with a leaf rake.
    And when your arms and back get tired, take a break and read some Inspirational Stories. Do what they did. Some of those pools looked worse than yours initially.
    Casey's Avatar
    SW PA
    10,428
    You will find that all of our responses will be repedative. All of what you seek and then some, will be found in Pool School (button top right of every page).
    You will need a test kit like the TF100.
    A leaf rake like Richard posted.
    Liquid chlorine
    Knowledge.... Understanding what we tell you and you'll only get that from actively participating in pool school.
    Welcome to TFP. Well be here to answer all you're questions.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Good job ordering a TF100, it is my fave test kit.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some intro Pool School articles to read while you wait for your test kit
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    May 2015
    Roseville, MI
    10
    Been pulling gunk out using this guy http://imgur.com/CEqO256
    When should I turn the filter on? Should I get it up and running and watch the pressure? I grabbed 5 cases of bleach to start. Test kit should be here tomorrow! http://imgur.com/6eKh8Y3
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by Detroit306 View Post
    Can't see it. You ran out of picture space. Easiest is to open an account at some photosharing place and then just post the URL. Photo tutorial
    If the dredging is coming up empty, then, yes, I'd say it's time to fire up the pump and see that it works. You'll have to have circulation to do the SLAM, and it'll need to mix well before you take your first pool chemistry readings.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Richard beat me to it, but I was going to suggest the same.
    May 2015
    Roseville, MI
    10
    Should be ok now? Will continue dredging tomorrow. Glad I'm not surrounded by trees.
    May 2015
    Roseville, MI
    10
    So we have liftoff http://i.imgur.com/rhVxqXz.jpg
    Backpressure http://i.imgur.com/ZpGumiO.jpg
    I quickly found out what the spare o rings were for http://i.imgur.com/B6eZxYL.jpg
    My returns seem to be shooting air? Normal? Concerning?http://i.imgur.com/pZcZoLe.jpg
    22K Inground swamp, concrete, hayward SP, sand filter.
    May 2015
    Roseville, MI
    10
    Pool has been running for about 2 hours now, couldn't get a chlorine reading ( makes sense) Cya less than 20 and ph was reading 8.2
    Richard320's Avatar
    Jan 2010
    18,984
    Okay... air in the returns is normal after you start the filter up after it's been empty. If it persists more than fifteen minutes, you got problems. It should have gone away pretty much in about two minutes.
    You'll need the TA reading to calculate the acid dose to lower pH. Your pH may be higher than 8.2, since that's the limit of the tester. Just enter 8.2 now and 7.2 target and whatever the TA values is currently. Add the acid. Let it mix, and see if you hit it. You might need a second dose.
    When pH is good and the filter is working properly, hit it.
    May 2015
    Roseville, MI
    10
    Returns did not clear up, bubbles for sure. Are they cracked? Would I notice a significant loss of water if that's the case? Skimmer seems to be slowwww
    Richard320's Avatar
    Jan 2010
    18,984
    You have an air leak on the suction side of the system. That's skimmers to pump outlet. Common causes are low water level, the flapper in the skimmer stick, the gasket under the pump basket lid, the drain plugs on the pump, and the fittings. I'd go over everything again, especially those unions with the O-rings. And look in the skimmers. You don't want to see whirlpool with a vortex sucking air.
    May 2015
    Roseville, MI
    10
    I don't see any gasket on that skimmer, and that drain cap had a leak I didn't notice, I can't get it to deal will have to figure out something at home depot. Made a video to show what I got going on https://youtu.be/anAkJHuKh5s
