Results 1 to 18 of 18
Thread: Check valve issues/need a recommendation
    Hey guys, hope this is right section for this...
    We installed a solar controller and all was good until today. The solar panel has a pinhole leak, and I assumed when the controller shut the flow to the panel off the leak would stop...not the case though. I'm thinking the check valve isn't closing and allowing water to flow back to the panel. I manually shut off flow to the panel with the pvc ball valves and when I opened everything back up the leak stopped. So it seems like when flow to the check valve is cutoff the flapper has a chance to close and do its job, but the solar controller turning the valves doesn't give it that chance and the flow continues.
    Does this sound like what's going on? Do I need a different better check valve?
    Pipe is 1 1/4"
    24' AGP, 54" - 13,300 Gallons at 47".
    AquaRay Cleaner
    Hayward Swimpro Voyager Filter/2 Speed 2 HP Pump
    38,521
    Re: Check valve issues/need a recommendation
    No idea what kind of check valves those are, but I am guessing the flapper type (see Neverlube) for pools work better.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    May 2015
    Fort Myers, FL
    7
    I would replace both of those flex sump pump fittings, they are only designed to hold a little water from draining back into a sump pit. With those you are on borrowed time, the entire flex fitting is usually only rated to 4.3 psi. Your 2 hp pump has the ability to blow those out very easily draining your pool below the skimmer in minutes, leaving your pump running dry. I would look at the Jandy ones linked below or find a rigid flapper style that is sched 40 and hard pipe it, no flex couplers. Flex connectors are not pressure rated.
    11k IG polyurea lined gunite pool and spa, Pentair EasyTouch w/ IC20 SWG, 2 x Pentair 1.5HP Whisper, Pentair CC150, AquaCal Heat Pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Some solar valves have a pin hole drilled in them (either at the factory or by the installer) to allow the pipes to drain back when the pump is turned off. The factory ones have a tiny check valve in them, the installer drilled ones don't.
    So I need the spring and not the flapper style?
    AquaRay Cleaner
    38,521
    Quote Originally Posted by xray328 View Post
    That is opposite of what we suggested. Although the flapper style do have a spring too.
    Ok I guess I'm confused because that link says its a spring check valve
    AquaRay Cleaner
    May 2015
    Wildorado Texas
    252
    Unless it is what's called a "swing check" it's going to have a spring on it. You have flap type check valves either with or without the spring - and ball and seat types (commonly called 'ball check'), also with or without the spring.
    38,521
    They all have springs, but the way they seal is different.
    Ok thanks. So if I get the linked valve sounds like Ill be good.
    AquaRay Cleaner
    May 2015
    Wildorado Texas
    252
    Swing checks don't have any type of spring, they rely on back pressure in the line and/or gravity to do the sealing.
    May 2015
    Wildorado Texas
    252
    Here's a example of a swing check, not applicable to you since it is larger diameter that what your process line is, but you get the idea.
    http://www.amazon.com/Valterra-200-C.../dp/B0064TQ2WQ
    38,521
    Well, the pool swing/flapper check valves like in the link do have a spring. But they add less head loss than the cheap PVC check valves.
    May 2015
    Wildorado Texas
    252
    Personally I wouldn't use a no-spring swing check in this application, for sure. The spring requires pressure to open, rated by the spring used. No-spring checks require only flow to open.
    For example a spring loaded check valve rated at 5psi won't open at 4. The springs are color coded too.
    Lots of good info here, thanks. Can someone link me to the actual check valve I need though? I don't mind spending the extra $, just want to do it one time
    AquaRay Cleaner
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    The valve linked in the third post is the type most people use. It's a Jandy spring check valve. It has a flapper that is held shut with a small spring.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Ok, thanks. 2 on the way, thanks again for everyone's help
    AquaRay Cleaner
