Thread: Need to Remove Booster Pump?
    Apr 2012
    Warrenton, VA
    27
    Hello everyone.
    Just bought a Dolphin Nautilus robotic cleaner and love it. Thanks for all the information in the other forum tab.
    My question is I have a booster pump (that is on its last leg/season) that will no longer be needed. Obviously I don't have to cycle it through my control panel but do I need to remove this pump. I don't plan on using it anymore. The wife says I should keep it where its at in case the the Dolphin dies which sounds smart. But not using the booster pump for a long duration, will it causes any issues?
    Thanks for the help.
    2004, 22.5K Gal., 36x18, IG Gunite, 2HP Hayward Pump, Hayward Sand Filter, Raypak 406 NG Heater, Dolphin Supreme M4 Robot, Automatic Cover
    Re: Need to Remove Booster Pump?
    Leaving it in place is fine for several years, though given enough time it is likely to eventually cause a problem.
