View Poll Results: Do you have air bubbles in your Liquidator flow indicator?
Voters
6. You may not vote on this poll
  • Yes
    4 66.67%
  • No.
    2 33.33%
Thread: Liquidator flow indicator....
    Aug 2014
    Shallotte, NC
    693
    Hasa provides the Liquidator to feed liquid chlorine to your pool. One of their purchased parts is the flow indicator, which is a Pentair part. I have identified a mis-match in threaded connections between the flow indicator and other fittings, such as hose barbs. The purpose of this poll is to determine if you have a leak at these fittings or not...
    Aug 2014
    Shallotte, NC
    693
    Re: Liquidator flow indicator....
    Bump..... Anybody?
    Ellington, CT
    262
    Yes, my flow indicator leaked. I thought it was cracked and i tried fixing it with a sealing putty but it still leaked. Your explanation of a fitting mis-match seems more likely. Anyway, I found that I really didn't need it and have been running without one since the beginning of last seasons.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Orlando, FL
    690
    I do not have bubbles or leaks. I have had it for about five months.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
