Thread: 2nd year 1st opening with TFP method
    Jul 2014
    Williamsport, PA
    6
    Started pump 3 days ago and adjusted my levels and started to slam. All is going well but my water is not clearing up. Just Cloudy Blue Color.
    Current test results.
    FC - 7.0 - adjusted back to 12 checking & raising every 3-4 hours
    CC - 0.5
    TC - 7.5
    PH - 7.8 (lowering was 8+ 2 days ago)
    TA - 80
    CH - 40
    CYA - Less that 30 (Dot does not disappear)
    I know I need to raise my CYA and that will also lower my PH so I'm not going to try to lower my PH any longer. What would you recommend? Raise my CYA and just keep slamming and wait it out? If I add Stabilizer it says not to backwash for a week but in my present situation I will not be able to do that since I'm slamming and I've had to backwash at least once a day to keep my pressure down and flow up. Any thoughts?
    Thanks for all your reply's.
    Stan
    27' Above Ground w/ new vinyl liner 6-30-14 - 17,000 gallons - Haywood Power-Flo Matrix 1hp pump - Haywood Pro Series model S166T sand filter - Talyor K-2005 test kit w/ FAS/DPD kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: 2nd year 1st opening with TFP method
    If you follow the sock method we recommend for adding CYA, there's no fear of losing all the CYA, because it's not inside the filter. How to add each chemical is in Recommended Pool Chemicals.
    Sand filters take a long time to clear the cloudiness. Have you considered adding DE to the sand filter? It's mentioned in the SLAM article.
    Jul 2014
    Williamsport, PA
    6
    Thanks for the reply. I'll add the stabilizer tomorrow. I did try the DE but within 15 minutes I had almost no flow through my pump and I only added 1/2 cup just to try it. Maybe I'll try a 1/4 cup tomorrow morning and see how that works. Thanks again!!!!!!!
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by schaya View Post
    The fast loadup means it caught a lot of stuff.
