Thread: Does cya evaporate?
    Apr 2015
    Central New York
    6
    Does cya evaporate?
    I know you need to drain water and add fresh water to reduce cya. Does it also go down when water evaporates? On a hot day I lose an inch of water. When I add fresh water am I lowering the cya as if drained and filled? Thanks.
    In-Ground,14000 gallon, 15x33 fiberglass pool, starclear plus 1200 cartridge filter, tablet chlorine feeder, Hayward 1.5 hp pump, unheated
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Does cya evaporate?
    No, the CYA stays in the pool, it does not evaporate. When your poo level goes down due to evaporation the CYA level actually goes up, but it is such a small amount it really can't be seen in the testing.
    Support the site
