Thread: Intex SWG pairing with stock pump/filter
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Question Intex SWG pairing with stock pump/filter
    Hello,
    Sorry, I am sure this has been asked, but I couldn't find an answer to my specific question.
    I have an Intex Ultraframe 18x48 still in the box.
    http://mobile.walmart.com/ip/Intex-1...-Pool/22474583
    I am interested is using a SWG, but know little about them so far.
    I just wanted to get a basic Intex system.
    http://www.amazon.com/Intex-Saltwate...ntex+saltwater
    My question is, can I just hook this up to the stock 1500gph pump/filter that comes with the pool? At least until I can afford a sand filter upgrade that is, probably next season.
    Also, how long should the filter run per day with this installed? I imagine longer that with just the stock setup as this will add a restriction.
    Thanks!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,548
    Re: Intex SWG pairing with stock pump/filter
    Yes, you can hook that up to the pump you have. How long to run it depends upon your CYA (stabilizer) level in your water, how much use the pool gets, how much chlorine you lose daily to sunlight, etc. You'll just have experiment with it until you find a setting that keeps your FC levels in the desired range.
    I probably run mine 4-6 hours/day. I don't remember for certain and just opened up today for this year.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yes, that will work fine. It's been quite a few years and I don't remember the times. It varies over the season anyway. I would run the pump 30min before and after the SWG to make sure there was water flow.
    You need to run the pump and SWG long enough to make sure that your chlorine stays above the minimum level for your CYA level on the Chlorine CYA Chart.
    Here are some intro Pool School articles to read.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here is the Water Balance for SWCG pool.
    Here are the Recommended Pool Chemicals
    Use PoolMath to figure out how much to add.
