Thread: Possible Chlorine Emergency?
    May 2015
    River Edge, NJ
    7
    I have an above ground pool with an automatic chlorine feeder. I had the water tested today and for some reason there was no chlorine in the water at all. So I filled the feeder up to the brim with chlorine tabs. The problem is that when I turned the water shut off valve back on the pvc valve broke in the open position so I can't run the pump until I get that fixed. My question is, is it ok that the chlorine is just sitting in the feeder without the pool running? Will this damage the feeder or plumbing in any way?
    9K gal, AG vinyl, 1 HP Sta Rite Pump and motor, Sta Rite Posi Clear cartridge filter, Hayward automatic chlorine feeder, Hayward H100 100,000 BTU natural gas heater with electronic ignition and analog controls
    Re: Possible Chlorine Emergency?
    The chlorine in the feeder is fine with the pool pump off for a very long time without any problems.
    On the other hand, the pool still needs some chlorine one way or another.
    Do you have water test results that you can post? Also, how does the water look?
    Casey's Avatar
    SW PA
    10,418
    I would be curious what your test results are, especially your CYA level.
    You can manually chlorinate with liquid bleach and brushing the pool thoroughly. Right now, that is your only option without a working pump/filter.
