Results 1 to 15 of 15
Thread: From "Pool Schooled" to True Pool Knowledge - A Journey
    May 2015
    Smyrna, TN
    3
    Hello from Middle Tennessee about 25 miles southeast of Nashville. This is a historical record of my Pool Store Schooling. We purchased a new pool in 2011 and we’re told the glories of the Perma Salt system, add one bag of this every two weeks and one bottle of this every week check the water with these test strips and that’s the only maintenance required for this system. I had never owned or maintained a pool before so this sounded perfect. In hindsight TOO GOOD TO BE TRUE and everyone knows what that means. The first season the pool water appeared to be crystal clear and I loved the low maintenance routine of checking the water once a week and dumping the bottle after checking. Set the reminder on the phone to remind me every two weeks to dump the bag of magic powder and we we’re in bliss. Of course the copper and Perma Salt system was not making my daughters blonde hair turn a shade of light green it must be the neighbor’s chlorine pool doing that. We closed the pool that fall following the pool store system and when we pulled the cover off in the spring I was amazed that we had an above ground cow cooling pond. The only thing missing were frogs and lily pads. The pool store said I waited to open the pool too late and the abundance of early rain was the problem so after a bottle of algaecide and several trips to the pool store for chemicals and advice, several weeks later the pool finally cleared up but never had the same crystal clear look as the year before and always seemed to have little spots of algae reappearing almost immediately after I vacuumed the pool and the bottom of the pool had a slippery texture it did not have the year before. I now know why. We repeated the same cycle in the fall and spring with the same summer results. I know the definition of insanity right but it still had to be the neighbor’s pool turning my daughter’s hair green and now causing her swimmers ear infections because I replace the copper cartridge every year and follow the “System” for maintaining the pool chemical levels. The next fall I decided not to cover the pool and opening the pool was easier but soon after we discovered we had occupants in our pool called backswimmers. You guessed it they enjoyed the pool much more than we did all summer. I went on backswimmer hunting expeditions daily and the only advice I got from the pool store was I need to add more algaecide (which they were happy to keep selling me) to kill the algae because that’s what these critters feed on. Needless to say the only thing that got rid of them was Mother Nature and something called winter. Now we are caught up to the day earlier this year when I was searching the web for Perma Salt system chemicals and stumbled upon the holy trinity for pool owners, This Web Site. After reading thread upon thread I felt like I had to stand up and admit “Hello my name is Scott and I have been Pool Schooled”. I must admit after taking several days to read through the Pool School steps I was convinced and made the leap of faith to convert to the TFP method of pool maintenance. I began this process in mid-April and purchased the Taylor TF-100 Test Kit and got to work. I can’t believe the difference and now know one other thing that takes care of backswimmers. I’ve made some mistakes in the process, for one thinking my initial SLAM was complete before I passed the overnight loss test. I am currently in my second SLAM effort but am fully confident I will be successful this time. Before I began this 2nd attempt all my readings we’re holding steady except my FC which was dropping like a rock which lead me do the overnight loss test every night to determine what was going on. I was dropping 6-10 ppm on consecutive nights thus my 2nd SLAM attempt. First night loss this week was 8ppm, second night loss 4ppm, last night loss 1.5 ppm so I now know patience is a virtue and I think I’m one night away from success.
    Last readings this morning at 7:00am were:
    FC – 19.5 shooting for 20 for my shock level. 22ppm last night at 9:00pm
    PH – 7.5
    TA – 110
    CH – 75
    CYA – 50
    CC – 0
    Copper < 0.3 using the strips provided by the store at the time we purchased the pool.
    Thus concludes my journey to a trouble free pool and I will keep you updated on true pool bliss this summer. A couple of pictures are attached. Thank you for one great informational web site.
    30.5K A.G. 2011 Middle Tennessee, ECOKleer 80gpm, Cartridge Filter- Pleatco Pure, TF-100 Test Kit.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: From "Pool Schooled" to True Pool Knowledge - A Journey
    Looks great! You want to make sure your OLCT is 1 or less ppm loss and then you will be done.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Thank you for your kind words! Your pool looks great! Should be passing that OCLT any day now!
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Welcome!
    Great testimonial. Wonderful first post - test kit already!
    Question: after selling you hundreds of dollars' worth of snake oil, did the pool store try this one?
    May 2015
    Smyrna, TN
    3
    No my Ex-Pool Store never mentioned this simple process of pool maintenance, I Wonder Why ($$$)??? Knowledge is a powerful thing and I'm now knowledgeable enough to know my New Pool Store is anywhere that has Bleach, Baking Soda, Borax or Muriatic Acid ON SALE!!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Congratulations and thanks for the testimonial...
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    You win the Golden Pool Noodle of the Week Award!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    great post! Keep slamming until you pass the OCLT. After that maintain recommended levels and you will not even believe how easty and inexpensive it is to keep your pool sparkly.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    We always love to hear the success stories!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP and great job on turning your pool crystal clear!
    38,406
    Welcome to TFP!!!
    Great story with a happy ending
    And that pool water looks fantastic!!!
    May 2015
    Smyrna, TN
    3
    Well it's official, after 4 days of slamming beginning Saturday morning we have gone two consecutive nights with a FC loss of <1. I almost couldn't believe it after my first test results yesterday morning so I verified again last night with a FC loss of about .5. I am now going to let the FC drift down and maintain at the target FC level for my CYA. This site has been a blessing because my water has not looked, felt or smelled better than the day we initially filled it. It is now time to truly enjoy the fruits of our pool opening labor. The true testament that I made the right decision to convert to this method of pool maintenance was when my 12 year old daughter told me yesterday when her head popped up above the water with a big grin on her face "Dad I can see all the way across the pool now, my eyes don't burn and the pool floor isn't slick and slimy feeling anymore". I'm totally sold now and will never use any other method. Thank all of you guys for the excellent information provided on this site.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Thanks for posting. I LOVE seeing these threads with pools and owners both transformed and in control.
    Enjoy that sparkling pool all summer!
    Isolated Spa - 345 Gallons
    30,427
    What a very nice testimonial. Thanks for sharing and thanks to all the veterans here who pony up there time and knowledge to help all the newbs.
    Casey's Avatar
    SW PA
    10,453
    Pool looks great! Welcome to TFP!
