Coudy water, how long to clear
jonmar
269
I noticed my water was cloudy this morning. I did a test and came up with:
CL-2 -CC-0
PH-8+
TA-100
CYA-80
CH-370
It's a salt pool. I immediately added acid and my PH is now 7.2. If the PH was the issue, how long should it take to clear the water? Any other suggestions?
I'd agree with Lisa. With the CYA at 80, I'd run the FC at least 4.
When I notice my pool being a bit cloudy, I'll usually boost my SWG and run the pump overnight. Pool will be crystal clear the next morning.
I agree with the others that your FC is low, but your cloudy water may have been a combination of your high CH and high pH causing calcium cloudiness.
With your pH being over 8 it would allow the ch to start precipitating, giving you that dull cloudy look.
Try keeping your pH to around 7.2 for now and run your filter for 24 hours to see if that doesn't help.
