Thread: Coudy water, how long to clear
    I noticed my water was cloudy this morning. I did a test and came up with:
    CL-2 -CC-0
    PH-8+
    TA-100
    CYA-80
    CH-370
    It's a salt pool. I immediately added acid and my PH is now 7.2. If the PH was the issue, how long should it take to clear the water? Any other suggestions?
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Coudy water, how long to clear
    It is hard to say how long it might take. Keep your filter running as much as possible and this will help. Glad you reduced PH. Looks like you need some FC in there though.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2007
    Suwanee, GA
    528
    I'd agree with Lisa. With the CYA at 80, I'd run the FC at least 4.
    When I notice my pool being a bit cloudy, I'll usually boost my SWG and run the pump overnight. Pool will be crystal clear the next morning.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    I agree with the others that your FC is low, but your cloudy water may have been a combination of your high CH and high pH causing calcium cloudiness.
    With your pH being over 8 it would allow the ch to start precipitating, giving you that dull cloudy look.
    Try keeping your pH to around 7.2 for now and run your filter for 24 hours to see if that doesn't help.
    Support the site
    Thanks for the help everyone. The pool was clear the next morning after adding 5L of CL
    38,487
    I would be a little more proactive and raise the FC up to 10+ and Perform the Overnight Chlorine Loss Test to see if there is a need to SLAM.
