Results 1 to 11 of 11
Thread: High TA
    May 2015
    Indianapolis
    11
    High TA
    I have an extremely high TA>300. My pool is 8,000 gallons. My ph is approx 7.6. How much acid should MA should I add at a time? I'm sure I'll have to do this multiple times since TA is so high. Need some guidance on this process please.
    7,900 gallons
    IG Fiberglass
    Sand filter
    Frog System
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: High TA
    You can use the pool math calculator to determine how much MA to add. You will have to go in several steps. Add MA, then test later in the day or the next day and repeat.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Indianapolis
    11
    Re: High TA
    I can't seem to get the pool calculator to work actually... I guess I should have said that before sorry!
    7,900 gallons
    IG Fiberglass
    Sand filter
    Frog System
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: High TA
    Are you selecting the the trouble free method at the bottom? What percent MA do. You have?
    Lisa
    May 2015
    Indianapolis
    11
    Re: High TA
    I think maybe i have the calculator figured out now. I believe the % is only 20 of my MA
    7,900 gallons
    IG Fiberglass
    Sand filter
    Frog System
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: High TA
    A few questions back at ya
    1) What test kit are you using? If it's strips, trust only the pH, and not very much.
    2) If it's a Taylor or TF100 kit, be aware that you can have static electricity on a fresh bottle of R-009. Check out Extended Test Kit Directions, notes under post 6.
    3) What are the rest of your readings? If you have high CH, you're probably at risk of scaling, so lowering TA is definitely called for. What's the CYA? If it's too high, you'll want a partial drain, so why treat water you're only going to dump?
    You probably want to review the Poolmath How-to and Lowering TA.
    All that being said... 6 cups of 31.45% acid should put you down to 7.2 or 7.3 pH. You'll see a reduction in TA of about 20 after the first round.
    May 2015
    Indianapolis
    11
    Re: High TA
    Suggestions on how to add MA? On the bottle it says to submerge bottle and tip over to pour in. Is this acceptable?
    7,900 gallons
    IG Fiberglass
    Sand filter
    Frog System
    Richard320's Avatar
    Jan 2010
    18,984
    Re: High TA
    Quote Originally Posted by MEdlund View Post
    Sure. Then it sort of floats, and if it does spill, it spills in the pool. Just be sure it's in front of the return stream so it mixes fast.
    May 2015
    Indianapolis
    11
    Re: High TA
    Got it! Thanks! Going to test water now.
    7,900 gallons
    IG Fiberglass
    Sand filter
    Frog System
    May 2015
    Indianapolis
    11
    Re: High TA
    Today I got a TA reading of 220 and Ph of 7.7. I believe there is some calcium build up along the water line. This means I should try lower TA correct?
    7,900 gallons
    IG Fiberglass
    Sand filter
    Frog System
    Richard320's Avatar
    Jan 2010
    18,984
    Re: High TA
    Still waiting for CH and CYA readings. There comes a point with Calcium Hardness where nothing you can do will stop scale from forming. It might be time for a partial drain. Who knows?
    Waterline stains can be dissolved with 1:3 acid in a spray bottle and some scrubbing, or a pumice stone and some aching knees and shoulders.
