Results 1 to 10 of 10
Thread: Need to lower TA
    May 2015
    Arnprior, Ontario Canada
    21
    Question Need to lower TA
    Question! My TA is at 180, is this too high, do I need to lower it? Using the HTH 6-way test strips my readings are as follows FAC = 3; TCI = 3; Alk = 180; pH = 7.8; CyA = 30-50. Aquarius 3 way testing is FC = 3 and pH = 7.8 Salt is at 4140.
    Intex Ultra frame 16'x48" above ground; Intex 2800 GPH Sand Filter Pump; Intex Krystal Clear Saltwater System Model# CG-28669; Hayward H100ID1 gas pool heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Need to lower TA
    Welcome!
    No, you don't need to aggressively lower TA. But you do need to lower the pH. Lowering the pH will slightly lower TA. Just keep the pH in range and TA will come down over time.
    You would do well to buy a better test kit. Strips are not reliable. The colors can bleed or bleach out with high FC levels, and if they get damp, they might appear to work but they won't be accurate. You're at a disadvantage in Canuckistan because TFtestkits can't ship there and the good Taylor test kits are massively overpriced up there.
    May 2015
    21
    Quote Originally Posted by Bon View Post
    Thanks Richard320!
    I should have mentioned that the Aquarius 3 way is OTO. I did the poolmath, it's recommending that I add muriatic acid in which I don't have. I have the HTH pH minus, will this do the same? If so, how long do I wait to do the test again?
    Richard320's Avatar
    Jan 2010
    19,046
    Thanks Richard320!
    The dry acid pH Minus will do the same thing. Since you have it, use it. But when it's gone, hunt for some Muriatic Acid. It's generally cheaper and doesn't add Sulfates to the water.
    If you've got things set up to aerate vigorously, a couple hours ought to be sufficient to see the pH rise again. From personal experience, the first round knocks TA down a lot. Each additional pH adjustment requires less acid and gets less TA drop and takes longer for the pH to rise again. So just expect it, and don't panic if things seem to be slowing down.
    May 2015
    21
    Great!!, GTG and lower the pH! Thanks a bunch!!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    You've already been given some good advice so I will merely welcome you to TFP!
    May 2015
    21
    Ok, so I backwashed my filter with the intensions of removing water because the salt level was too high (4140). I added more water, tested the salt level the next morning and it was too low (1970). Added more salt (now @ 2310), it's rising however about an hour later, the pool seemed to be cloudy.
    I just tested the water balance and my readings are as follows using Aquarius 3 way OTO test FC = 3; pH = 7.8.
    Using the HTH test strips readings are as follows... FAC = 3; TCI = 3; AlK = 180; pH = 7.8; TH= 250; CyA = 0.
    I know I still need to get my salt up to 3000 - 3400 I'm not concerned about that as my SWG isn't alarming. I need to know if I should add shock to the water or do I add something else such as pH minus or a stabilizer to bring up the CyA?
    Thanks in advance!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It takes about 24 hours for salt to dissolve fully and register on the test. You add CYA/stabilizer to increase CYA. See recommended chemicals link below.
    Here are some intro Pool School articles
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here is the Water Balance for a SWCG pool.
    Here are the Recommended Pool Chemicals to maintain yojr pool and how to add them.
    Use PoolMath to figure out how much to add.
    Casey's Avatar
    SW PA
    10,453
    Welcome bon. Hope things are working out for you
    May 2015
    21
    Quote Originally Posted by Casey View Post
    Thank you Casey, I'm still trying to raise my CyA, I've been adding stabilizer a little at a time. I just added the recommended amount needed according to the poolmath. Hopefully this will do it. This is my third year with the pool, my first year opening it up as it's an intex pool, you normally take it down and store it for the winter. All my other chemicals are good for now.
