Results 1 to 14 of 14
Thread: Intellichlor flashing high salt
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Does anyone have input on the accuracy of the Aquacheck salt test strips? Strips are measuring my salt at 3470 (yellow peak at 6-6) but SWG is flashing high salt. Manual says that puts salt above 4500.
    Is this more likely a fault with the SWG?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Intellichlor flashing high salt
    I have no idea on the accuracy of the strips, but I can say my Taylor salt set linked in my signature is great!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    The AquaChek strips are great most of the time, but are occasionally they are just wrong.
    It is not at all common for a SWG to break such that it displays high salt when the salt is actually normal. It isn't impossible, just very unlikely.
    Have you added salt recently? Adding salt within the last 24 hours will often cause the salt readings to fluctuate quite a bit until the salt has had more time to mix in.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Thanks JasonLion. I should have read my owners Manuel before posting because I believe I need to clean the cell. I haven't added salt in a while but last time was enough to get me to 3500. But I am slamming right now.
    Now.....to google how to clean the SWG. Have no clue.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I clean my salt water cell with diluted MA.
    Lisa
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I know that's what to clean it with. Don't know how to get to it. Maybe I'm over looking something very simple.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Oh,ok. I am not familiar with your SWG so I am not any help. Does it show in the manual at all?
    Maybe post a pic and someone will know.
    Lisa
    Feb 2014
    Upstate, NY
    390
    My Aquacheck salt strips were not even close.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Ain't YouTube great?
    So I watched a video on how to do it but that person said one would need a certain part to screw on the bottom to keep the acid in since the whole unit can't be submerged. I don't have that.
    I'll try to post a pic.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Fixed. It didn't need to be acid washed I don't think as the MA didn't cause any foaming but gave it a good rinse with the hose and maybe bought another year or two.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by AimeeH View Post
    Glad you got it fixed.
    Lisa
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I should add to this that all this occurred during a SLAM. Observation has shown that when the Chlorine is really high.....I'm guessing 30 plus it starts flashing high salt again. Once chlorine is back down it stops flashing. It took this week of slamming and observing to discover this. Nowhere in the owners manual is that mentioned. Just an observation of mine this last week. Fingers crossed that is the correlation and my salt cell isn't at the end of its life.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Bleach adds salt so that is probably why your high salt warning is going off. I did not use my SWG during my SLAM.
    Lisa
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    The high salt light flashing seemed to correlate to the high chlorine though. Bleach (sodium hypochlorite) does add some salt but that is small and isn't reduced by the chlorine coming down. But the light stops flashing when the chlorine comes down which I found interesting since that isn't mentioned in the owners manuel.
    It would take over 200 pounds of salt to put me in that 4500 "high salt" level that the manual says will trigger the high salt warning.
