Thread: What size motor?
    Jul 2014
    Harrison Township, MI
    41
    What size motor?
    Ok, my 1.5hp motor on my Hayward Superpump died. After asking some questions on here I have determined a few things:
    My old motor is a single speed 1.5hp with a SF of 1.3
    I want a dual speed motor
    I am having my electrical switched over to 230v so I can utilize a dual speed pump
    I have about 80' of skimmer lines (2 skimmers)
    I have about 50' of line to my drain
    I have 4 returns
    I have a Hayward S244T filter with 50 psi working pressure
    The guy at Inyo pools says I need a 2 1/2 or 3 hp motor! The pool seemed to run okay with the 1.5 hp motor last year, although it was our first year in this home so we have nothing to compare to.
    What size motor do I REALLY need for my set up?
    Thanks for your help!
    20x40 IGP w/ vinyl liner ~ approximately 30,000 gallons ~ Hayward 1.5hp pump ~ Hayward S244T Sand Filter ~ Hayward Gas Heater ~ 1 drain, 2 skimmers, 4 returns ~ Protect-A-Child Fence ~TF-100 kit
    38,532
    Re: What size motor?
    There is absolutely no reason to have a pump as big as they were suggesting.
    I would just get a 2 speed motor with the same HP & SF (or product of the 2) and put it on your existing pump.
    Nothing you wrote calls for high flow rates, so no reason to go bigger.
    This might be a good read for you as well: Determine Pump Run Time
    May 2009
    Youngsville NC
    395
    As long as the new motor has an SFHP of 1.95 or larger, it should work. If you are putting in a whole new pump, then you might consider a 1 HP 2 speed pump.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Jul 2014
    41
    Thanks guys! I ordered a replacement 2-speed motor with the exact same hp and sf. I appreciate your replies!
    38,532
    Good deal. You will need to add a manual switch. You can find some motor end caps that have a switch, or easy to use a household 3-way light switch between the timer and the motor.
