Results 1 to 15 of 15
Thread: Power out - question about maintaining FC
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    We had a tree fall on our power line coming to the house and the power will likely be out until Monday. My plan right now is to test FC a couple of times per day and adjust the level with bleach as needed. Since the pump won't be running, I'm going to brush the pool to keep things circulated. Sound like a good plan? Any other suggestions?
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Power out - question about maintaining FC
    It's about all you can do. You may want to add a little "extra" over what your normal FC would be but not up to shock level.
    My wife wonders why I have a whole house generator....
    Support the site
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I bought a portable generator JUST to run the pump if need be.
    Donldson's Avatar
    NW Ohio
    2,881
    The brushing will be key, helping circulate everything. If it is warm enough to swim, hop in and get the water moving. Add chlorine either right after swimming or right before brushing. If everything was balanced to TFPC specs before the power loss then the pool should have no trouble handling a couple days without the filter.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    Everything was balanced per TFPC recommendations. It's rainy and cool this weekend so I think I'll stick to brushing.
    May 2014
    Franklin, NC
    9,184
    Rainy & cool is a good thing, it should hold down the chlorine demand.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Now you have a good excuse to buy a wall whale brush, if you don;t already have one. It can move some water. Brush down one side and halfway across the floor and wait for the wave to erupt on the other side. Just don't put the flap to maximum angle. It's a good way to bend the pole. Ask me how I know....
    May 2014
    Franklin, NC
    9,184
    Richard, you are truly a manly man. I can't get that thing to move on the max angle.....
    Support the site
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    Never heard of the wall whale until now. Might see if someone local has it in stock.
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    Quote Originally Posted by SunnyBama View Post
    You should be fine. When my pump went out and couldn't get a replacement for about 10 days or so, I did what you're considering and didn't have any issues.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jul 2008
    McDonough, GA
    97
    Get a boat paddle and practice your rowing skills to circulate your water
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Got a small outboard motor handy?
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Jul 2014
    Independence, KY
    220
    Take a 5 gallon bucket and drag it into the pool as if you were filing it with water. Then dump it back in the pool. Then repeat. You may want to move to various sections of the pool and repeat. You would be surprised how much water you can move by doing this.
    I actually use this to mix in bleach into the pool.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Or do what I did a couple of years ago and hook up a small diesel powered water pump
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Check out this post from someone who was without power for a week or so while daytime highs were near or above 100F: http://www.troublefreepool.com/threa...roblem!!/page2
