Results 1 to 11 of 11
Thread: Chloramine and FTP méthod
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Hello,
    I have a quick question this morning.
    Why i have limited chloramine if i use thewTFP method?
    Envoyé de mon iPhone en utilisant Tapatalk
    Sorry for my english, je suis francophone
    I live in north, no ice in my pool since may 1 !
    Stylus aboveground swimming pool 45 000 liters
    18' round and 52" high with sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,057
    Re: Chloramine and FTP méthod
    Chloramine is the bad stuff. That's what smells like a public pool. You want none. I hope that answered the question.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    If you mean CC-----combined chloramines----the bad stuff, it's because you are keeping your FC in range with your cya and the rest balanced too.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by YoRgH View Post
    Hello,
    If you follow the guidelines here you will not. If you are doing a SLAM procedure, part of it being completed is Less than 1.0 PPM CC. After that, with proper consistent balance, you won't have any.
    Essential Links:
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    It is more a chem question. Why the chloramine formation réaction stop ?
    Apr 2010
    East Texas
    9,655
    Because a high enough FC will sanitize and................oxidize..........(break them down) those formations.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by woodyp View Post
    And the Sunlight will as well.....
    Essential Links:
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Ok, keeping my solar cover may cause chloramine rising ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not if you have it off regularly for any reasonable amount of time, no. I think you are overly concerned about this issue. While CC is very important, it's rarely an issue in residential outdoor pools that are maintained fairly well in terms of Chlorine balance. Very rarely....
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Chloramines are formed when chlorine reacts with ammonia and some organics. In a low bather-load pool such as most residential pools, there is a very small amount of such ammonia and organics being introduced into a comparatively large amount of water. Chlorine will continue to oxidize most chloramines to final end products which is why you don't normally see a buildup of Combined Chlorine (CC). The UV in sunlight also helps by both directly breaking down some chloramines (dichloramine in particular) and indirectly by breaking down chlorine to produce very powerful but short-lived oxidizers called hydroxyl radicals. These hydroxyl radicals can oxidize some organic precursors before they get a chance to react with chlorine to form chloramines.
    The only thing special about the TFP method that results in a more consistently lower CC is that a reasonable active chlorine level is maintained in the pool at all times. Accurate measurement and consistent dosing result in consistent disinfection and oxidation.
    My own pool has a mostly opaque electric safety cover on it except when the pool is in use nearly every day for about an hour at which time at least part of the pool is exposed to sunlight. I consistently measure < 0.2 ppm CC (i.e. the limit of detection in the FAS-DPD chlorine test using a 25 ml sample size). It's most likely < 0.1 ppm CC and the primary component of CC is likely to be monochlorourea which is innocuous.
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    Quote Originally Posted by chem geek View Post
    Thanks for the explantation!
