Thread: CYA Chemicals in a Sock
    Hello,
    I purchased some CYA chemicals at the pool store and was advised to put the chemicals in a sock under the skimmer basket. I left the sock under the skimmer basket for 3-4 days and returned to find that the sock was no longer under the basket. I eventually found that it had been sucked through the system into the basket where my pool equip is located. Going Forward, should I put the sock "in" the bottom of the skimmer basket by the return?
    I live in the Albany NY area. The size of my pool is 24,000 gallons. The pool is an In-Ground rectangular Double Roman with a vinyl liner. I am using a Taylor K-2006 water testing kit. I have a DE filter. I have a regular chlorine pool. The pool cleaner is a 2017 Dolphin Premier Robotic In-Ground pool cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Re: CYA Chemicals in a Sock
    It sits in the basket, not below it, for exactly the reason you just gave. Pool Store advice at it's finest.
    And why are you still listening to it?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I am really surprised they told you that about the Sock method. Someone has been reading here.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Doh! They are half right again! Pool store shmool store.
