Thread: If it's raining and a solar blanket is on the water?
    Aug 2014
    East Northport, NY
    155
    Do you need to run the pump? I assume the answer is yes but probably not for as long as normal?
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: If it's raining and a solar blanket is on the water?
    Are you using the SWCG? The pump needs to run at least as long as the SWCG needs to chlorinate the pool.
    Support the site
    Aug 2014
    East Northport, NY
    155
    right now since its pouring and overcast I am running neither.
    TF-100 Test Kit
    Aquabot Bravo
    May 2014
    Franklin, NC
    9,184
    Are you manually adding chlorine? The pool still consumes chlorine when its cloudy and raining. You gotta keep the FC up. It uses less in these weather conditions, but it still uses it.
    Support the site
    Aug 2014
    East Northport, NY
    155
    yep that's what I figured. Thanks.
    TF-100 Test Kit
    Aquabot Bravo
