Thread: Pool light ground wire
    May 2015
    poer St Lucie, Florida
    5
    Hey guys. I'm new here and trying to get some help. Trying to take out old lighting fixture that was bad and having a problem with pulling the wire out. In doing so I took off the sealant that covers the ground wire and screw. My question is, when I do run new wire to a new light and reattach existing ground wire , does the ground wire need to be sealed again from the water ? If so,with what ? Hoping that it doesn't because I will have to drain water to seal it. Thanks for any help !!!
    Jun 2012
    western NY
    1,562
    Re: Pool light ground wire
    That is the bonding wire and yes it needs to have the connection sealed to prevent corrosion and possible loss of bonding.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2014
    Los Angeles, CA
    104
    3M scotchcast 2136 potting compound is what you want to use.
    -Shotcrete Pool. Pebble Sheen. Tile by Dal Tile CW27 Winter Blues. Pool dimensions 45x19 24,360 gallons. Spa dimensions 7x7 825 gallons. -Hayward Equipment: OmniLogic, Main filter pump Ecostar SP3400VSP, Spa pump Ecostar SP3400VSP, Filter 700sq ft Cartridge Filter HCF7030C, T-Cell 15 SWG, GVA 24 valve actuators, Universal ColorLogic 12v LED lights, H500FDN Natural Gas 500,000 BTU heater, TF100 test kit.
    May 2015
    5
    Thanks guys !!!
    I got one more question, If I don't put a new light in does that bond wire still have to be connected and sealed?
    Yes, the light niche requires a properly connected (i.e. potted) bonding wire, with or without a light installed.
    May 2015
    5
    Thx u Jason. I'm still trying to pull that darn old wire out.
